Author Topic: Glue versus Woodscrews - which should I use?  (Read 15824 times)
Dreamwriter
  • Last login:August 28, 2010, 04:33:09 pm
  • Sleep is for the weak!
    • Games of Yore
« on: August 13, 2006, 09:27:32 pm »
So I'm making my little desktop arcade machine (check it out under Project Announcements, Project 42), and I was thinking I was gonna just use woodscrews for the whole thing, but it was suggested (by my woodworking friend) that glue might be better.
So is there a good reason to use glue over woodscrews?  This thing isn't going to be big or anything, so once assembled only the bottom should ever need removing.  Thanks for your advice!
releasedtruth
  • Last login:April 11, 2018, 12:06:49 am
  • Projected Nexus
Re: Glue versus Woodscrews - which should I use?
« Reply #1 on: August 13, 2006, 09:57:52 pm »
If it's that small you could certainly use glue, but dropping some screws in there for strength certainly wouldn't hurt any. Besides, no sense not erring on the side of caution.
NightGod
« Reply #2 on: August 14, 2006, 03:57:00 am »
Both FTW.
I'd rather have my cab be TOO well built than not well enough.
« Reply #3 on: August 15, 2006, 10:37:02 am »
Both.  Drill pilot holes, pull the pieces apart, glue, then screw.
That way you don't have to clamp.
nostrebor
  • Not enough wit to effectively use this space...
  • Last login:October 04, 2013, 02:02:41 pm
  • SHOCKING!!
« Reply #4 on: August 15, 2006, 10:47:22 am »
Both.
WillBurne
  • Last login:January 23, 2008, 05:51:54 pm
« Reply #5 on: August 15, 2006, 10:08:06 pm »
Both
Well, glue and some appropriately sized finish nails instead of screws. Use a pilot hole and a nail set. You'll find all the strength you need for this size project. Screws are definitely overkill and provide large holes to fill.
I always overkill on entryways and high traffic areas.
BackAgain
  • Last login:February 01, 2008, 03:27:44 pm
« Reply #6 on: August 17, 2006, 12:16:54 am »
I agree with WillBurne.  Glue & finish nails.  I have tons of nails holding my house together and no screws.  ;D
NiteWalker
  • Last login:April 25, 2022, 07:33:24 pm
  • Routers can do anything.
    • SimpleCase Custom Arcade Stick Enclosures
« Reply #7 on: August 17, 2006, 02:12:34 pm »
That about says it. Use coarse threaded drywall screws if it's MDF you're making your project out of. Sorry I haven't checked it yet. On my way there now.
It's 9am. I'm calling it a nite.
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #8 on: August 17, 2006, 07:31:35 pm »
I'm sure somewhere there's a screw loose ;)
BackAgain
« Reply #9 on: August 20, 2006, 01:47:27 am »
Ya know, my wife told me I had a few loose screws, too.  I walked around the house for 3 days with a screwdriver and never did find 'em! :dizzy:
miles2912
« Reply #10 on: August 20, 2006, 03:58:50 pm »
I second the nomination for drywall screws and wood glue.  Just keep a damp shop rag handy to wipe off excess glue.
D-
flyguy1821
  • Last login:October 23, 2022, 11:06:19 pm
« Reply #11 on: August 21, 2006, 03:41:40 pm »
I use Gorilla Glue and regular drywall screws, course thread.  Only thing to be careful with polyurethane glue is expansion. The previous posters are correct though, the screws or nails are for temporary holding while the glue has a chance to dry.  Aren't we all about going overboard though?  I mean that is why this site was built and why we are making our own arcade cabs?!?  Go for it all, use lag bolts and weld some angle iron onto your cab!!!  She wont flex then!
NightGod
« Reply #12 on: August 21, 2006, 10:03:59 pm »
I have to say-I used to use Gorilla Glue and then, based on a thread here on the boards, tried out Titebond III and WOW that's amazing stuff. Bonds at least as well, no massive expansion issues, no Gorilla Hands. Check the stuff out.
« Last Edit: August 21, 2006, 10:56:04 pm by NightGod »
flyguy1821
« Reply #13 on: August 21, 2006, 10:34:48 pm »
Night God is right, the worst thing about using Gorilla glue is that it gets on your hands and you can not get it off!!  Never been a big fan about gloves either.
Stingray
« Reply #14 on: August 22, 2006, 01:44:14 pm »
I'll throw my vote in with both screws & glue or nails & glue. Also I second Titebond III, that's good stuff.
-S
Nannuu
  • Last login:May 23, 2022, 11:55:21 pm
  • Anytime now, I'll start my cabinet
    • Will and Liliana's Projects and Family Photos
« Reply #15 on: August 23, 2006, 12:00:15 pm »
I say both as well.  Even better if you get yourself a pocket hole jig to make hidden screws, no bondo to sand that way.  I have a Kreg PHJ, that thing is my favorite tool I own.
Next I'll be on fries, and that's when the big money starts rolling in.
MustardTent
  • Last login:February 22, 2015, 12:14:02 pm
    • Blog
« Reply #16 on: August 23, 2006, 02:04:57 pm »
No wood glue for me.  I've had to move the cabinet three times since I built it -- this required getting it through a doorway smaller than the cabinet.
In addition, I've taken it apart to perform some surgery as well.
Is everybody relying on the fact that they won't have to do these things?
(Agree on the drywall screws, though)
« Reply #17 on: August 23, 2006, 02:06:36 pm »
Pretty much, yes... don't build one bigger than the doorways.  Or make it modular.
MustardTent
    • Blog
« Reply #18 on: August 23, 2006, 02:13:09 pm »
What about stairs?  When they are steep enough or the ceiling is low enough (or the stairs have a turn) this doesn't solve the issue.
Or make it modular.
Let's see, what can be defined as a separate module (and be useful for transportation)?
1) CP
2) Everything else
Anything else that you make modular (for a standard upright) wouldn't help in the moving process.  I can make the marquee modular, but why?  It should be a simple process of removing that anyway.
We could get really modular and make the entire cabinet rely on panel clamps, but who knows how well that would work?
Nope.  No glue for me.
« Reply #19 on: August 23, 2006, 02:21:58 pm »
Or make it modular.
1) CP
2) Everything else
That's not true at all.  There are a lot of things that could be done to make it more modular than that.  Pretty much as many as the imagination could come up with.  You're limiting yourself to the standard shape/design of a tranditional upright.
MustardTent
    • Blog
« Reply #20 on: August 23, 2006, 02:28:07 pm »
[...] You're limiting yourself to the standard shape/design of a tranditional upright.
Agreed -- but, this is what most people have.  Now you're implying that a certain number of "tricks" are needed to make a cab sucessfully modular instead of breaking it up where it is most obvious.
However, is the extra work that comes with that worth it over simply not using woodglue?  My cab is just fine without it.
OP, either way is fine...I'm just saying I don't use wood glue and the cab is plenty solid.
MustardTent
    • Blog
« Reply #21 on: August 23, 2006, 02:32:27 pm »
Also, to ensure that I don't derail this thread, I made a new one in the "main" forum.  I'm interested to see what people have done.
« Reply #22 on: August 23, 2006, 02:40:17 pm »
I don't know that I would call imaginative woodworking a trick.
MustardTent
    • Blog
« Reply #23 on: August 23, 2006, 02:40:51 pm »
If you knew my skillset you would.  :banghead:
MustardTent
    • Blog
« Reply #24 on: August 23, 2006, 02:51:55 pm »
Lastly -- now we're at the point where we are discussing "imaginative woodworking" versus the use of woodglue.
Don't need much skill to *not* use woodglue, but you need it for modularity.  OK, I'm done.
Dreamwriter
    • Games of Yore
« Reply #25 on: August 28, 2006, 01:18:07 am »
I forgot this thread existed :)  So use both glue and screws it is then - a good idea, I do want to go overkill on this (though maybe not to the point of welding iron corners onto it..)  I have a feeling my little machine could be subject to a lot of abuse (I drop stuff a lot).  And I'm gonna be using plywood, BTW, though I'm not sure yet what type.
Gambit
  • Last login:November 16, 2006, 09:40:19 am
    • The BlueSparks Network
« Reply #26 on: August 30, 2006, 02:24:26 am »
Screws are NOT stronger than glue. Glue is stronger than screws.
The screws should only be used to hold the wood together while the glue dries.  Though if you plan on taking it apart in the future then only use screws.
Though do not use the type of glue used in the Project Arcade book. That type of glue is worthless for strength.  Use only woodworking glue.
flyguy1821
« Reply #27 on: August 30, 2006, 08:45:51 am »
i tend to use a lot of paste, the superior bonding properties give me that tight seal I am looking for.  And dont worry about it splitting when those little white crumbles dry, wow what a bond!
NightGod
« Reply #28 on: August 30, 2006, 08:49:55 am »
Plus, you can eat it when you get hungry while building!
bakechad
  • Last login:June 29, 2020, 12:13:07 pm
« Reply #29 on: August 30, 2006, 02:17:45 pm »
Another vote for Titebond III.  I used it last week to fix a cracked piece of trim outside.  I glued, clamped, and primed it 48 hours later.  You can't even tell the wood was cracked and it poured rain off and on for three days after I primed it and it's held up perfectly.  Great stuff.
I think glue and finish nails would work best if you are inexperienced(like me :)).  But remember Norm glues his furniture using perfect joints everytime, no screws.  But then again, I'm not Norm and I'm guessing your not either.
pgifford
  • Last login:November 07, 2007, 11:25:32 pm
  • I'm a llama and lloving it!
« Reply #30 on: September 05, 2006, 01:05:47 am »
For modularity, what about rigging up something like Ikea uses to hold their furniture together?  I don't even know the right words to describe it accurately so perhaps someone else with a house full of Ikea furniture can help out here.
Or what about some sort of latch that can be used on the inside to hold everything together, allowing the cab to be disassembled easily?
Perhaps bungee cords criss-crossed throughout the interior...
Paul
Tahnok
  • Last login:May 28, 2008, 06:09:25 am
  • Error recording error codes. Remaining errors lost
    • Table Arcades
« Reply #31 on: September 06, 2006, 01:48:31 am »
Paul
KD (knockdown) fittings. You can buy them here:
http://www.rockler.com/CategoryView.cfm?Cat_ID=115
I seem to have lost the link, but someone on here used them in their cab (which is where I was originally turned onto them). All my bartops have them and I can tell you that they aren't as big of a deal to get aligned as you may think.
Note: Out of town with limited internet access 2-28-08 through 3-16-08
Bartop/Countertop Cabinet Kits For Sale
Stingray
« Reply #32 on: September 07, 2006, 12:49:59 pm »
Probably not a good idea unless you want your cab to be as wobbly as Ikea furniture.
-S
elvis
  • Last login:January 13, 2025, 08:48:40 am
  • penguin poker
    • StickFreaks
« Reply #33 on: October 02, 2006, 05:35:07 pm »
Is your house made from MDF?   ;D
Where I'm from, coarse thread screws are the only way.  High humidity and temperatures means that anything nailed into fibre board comes out several weeks later, even with glue.
Structural pine and hardwoods are a different story, as they are a different material.
« Last Edit: October 02, 2006, 05:36:59 pm by elvis »
« Reply #34 on: October 02, 2006, 07:34:17 pm »
Dude lives in a pineapple under the sea.
Tahnok
    • Table Arcades
« Reply #35 on: October 03, 2006, 01:10:55 am »
-S
If used properly, you shouldn't have any problems with stability. I've never had any problems, even after assembling and disassembling several times.
spacies
« Reply #36 on: October 03, 2006, 02:18:17 am »
I dont use screws in my builds.
Too much filling and sanding involved and when using MDF the screw holes can buldge and require even more work.
I just use a 1" x 1" piece of timber on the inside of the cabinet all fixed in place with a pneumatic nailer with finishing nails and LOADS of glue on EVERY join. Once the glue is set it will 'rip' off timber but the 2 joins will still be stuck together.
And the best thing about it is there is NO filling and sanding on the external cabinetry  8)
Look Mom, no holes  :o
« Last Edit: October 03, 2006, 02:20:35 am by spacies »
kelemvor
  • Last login:May 13, 2012, 09:40:44 am
« Reply #37 on: October 03, 2006, 10:12:46 am »
Do you nail them from the inside so there's really no holes on the outside at all?
« Reply #38 on: October 03, 2006, 10:20:11 am »
That is the best combination of speed and quality, yes.
spacies
« Reply #39 on: October 03, 2006, 04:57:10 pm »
Yip  ;D
If you have an air compressor then go to your local hardware store and invest in an pneumatic nailer/stapler. Buy some nails or staples the correct size so they won't fire out the front of your cabinet and you are away laughing. Also buy loads of glue and some 1 x 1" block.
The staples/nails are really only there to hold the block in place while the glue dries. If you try to separate 2 surfaces that have completely dried you will see that the 2 joints will stick together and you have ripped away a fresh piece of wood, if you understand???
There are ZERO holes in the face of that cabinet. Makes for a perfect finish with less time involved. I do this for a living so time is important and so is the finished product.
Here's 4 good tips for you.
1: If you plan on building a cabinet then go out and buy a sheet of MDF about half the thickness you plan to use. Measure and draw out the complete side profile of the cabinet onto the sheet. Once happy with it, cut it out and keep working on it with sandpaper until it is perfect. Being a thinner peice it is easier to work with and MDF sands sooo easily.
Now place the new template under your correct size sheet and clamp in place. This is because the best way to cut it out is to use a router with a flush cut bit and you will get an exact copy on both sides. You could take the template to your local cabinet maker and get him to flush cut it. Probably wouldnt cost that much because its only a 5 minute job. If you dont have a router, then place the template on top and trace it out and then cut. Do the same with the other side and when you have them both cut out compare the 2 and tidy up so they match.
2: The other tip is when buying your materials, ask if the hardware store can cut a sheet in half. Now you have 2  2ftx8ft sheets (or whatever you need) . All you need to do is cut of the desired length you require beause you know they are already the same width. EASY EASY EASY.
Building classic cabs is a lot easier than building a big 4 player machine with sides that look like something from Star Wars. They were designed to be mass produced, with a style of their own of course, so the quicker and easier, the better. Have a look at my pic again and let me point out something. The top, the bottom of the marquee, the back of the marquee where the light screws on, the glass holder above the control panel, the control panel, the speaker front, the peice under the speaker, the coin front, the front and rear of the bottom plinth, the base, the rear top, the rear bottom, the rear door and the monitor shelf are all the same width. How easy is that? The only thing I had to custom cut were the sides and the sides of the bottom plinth! Stick with the classics, you cant go wrong.
Oh yeah, the 2 other things were mentioned above,  buy yourself a nail/staple gun and shares in a glue company.
« Last Edit: October 03, 2006, 05:06:05 pm by spacies »
