Author Topic: New (?) coin mech holder for coin doors  (Read 1588 times)
Level42
« on: August 13, 2006, 05:27:03 am »
Anyone has any experience with one of these ?
http://www.happcontrols.com/coindoors/42045500.htm
I only so far have seen the regular holding stuff which are all seperate parts, this seems to be one solid part to install ?
« Last Edit: August 13, 2006, 05:29:37 am by Level42 »
grantspain
Re: New (?) coin mech holder for coin doors
« Reply #1 on: August 13, 2006, 06:45:37 am »
i have both these types,i prefer type A as its a little more robust-you can use these for all mechs the size of an S10 including electronic.the one thing have to make sure is that these holders line up with your present coin door,otherwise you will be filing and drilling(also if anyone buys one of these make sure it comes with the insert and reject bezels)
Level42
« Reply #2 on: August 13, 2006, 02:33:06 pm »
Thanks, did you fit them to a Happ coin door ? I've got a happ coin door and a standard (IL=happ=suzo) mechanical coin mech. This should fit right ?
Level42
« Reply #3 on: August 13, 2006, 02:46:43 pm »
Do you mean these ?:
http://www.happcontrols.com/cc/420517xx.htm
