Author Topic: Roadblasters PS sending 15v instead of 10.3v  (Read 1749 times)
clanggedin
  • Last login:July 02, 2012, 11:08:55 pm
  • O'DOYLE RULES!!!
« on: August 08, 2006, 04:48:58 pm »
My roadblasters died a few months ago when a token accidentally bridged the gap between a couple of the fuses on the PS/ I replased the fuses and I get the 5v and 15v  that the game needs except when I check the line that supplies the 10.3v with a multimeter I am getting 15v. I know that this line is unregulated, but 15v seems too high. The game won't power on at all either, just the marquee and the monitor. When I check the test points on the mainboard I am not getting 5v either.
I do have a switching PS that I was thinking of installing just to test the 10.3v line with 12v. Would that possibly work??
Could 15v have fried my ARIII board and mainboard too?
« Last Edit: August 08, 2006, 05:55:04 pm by clanggedin »
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: Roadblasters PS sending 15v instead of 10.3v
« Reply #1 on: August 08, 2006, 05:17:24 pm »
Take them out and examine everything real closely for burnt up parts...
NO MORE!!
Ken Layton
  • Guru
  • Technician
« Reply #2 on: August 08, 2006, 06:03:08 pm »
The 10.3 volts is indeed unregulated so that means approximate. There's probably something wrong on the audio regulator board.
clanggedin
  • O'DOYLE RULES!!!
« Reply #3 on: August 08, 2006, 07:31:02 pm »
I dunno 15v doesn't sound approximate to me. 12v sounds approximate, but you know your stuff Ken so I'll check the Audio Regulator board to see if I can find any problems with it.
« Last Edit: August 08, 2006, 07:35:05 pm by clanggedin »
clanggedin
  • O'DOYLE RULES!!!
« Reply #4 on: August 08, 2006, 07:46:32 pm »
OK I pulled the AR III board and it looks like the big resistor at R20 is cracked, it is also brown around it. According to the System 1 schematics it says the resistor is a 2.7 1w. What does that mean??
Rocky
« Reply #5 on: August 08, 2006, 11:16:20 pm »
I get around 14v on the 10.3v unregulated line on my Food Fight. I don't think that is your problem.
If your AR board is putting out +5v, but you aren't getting +5v on the main board, it sounds like you fried something on the main board.
It's easier to troubleshoot if you know which board/part is bad. Do you have any spare boards or AR III's to test with?
Ken Layton
  • Guru
  • Technician
« Reply #6 on: August 08, 2006, 11:40:50 pm »
Sounds like 2.7 ohms at 1 watt to me.
clanggedin
  • O'DOYLE RULES!!!
« Reply #7 on: August 09, 2006, 12:46:08 pm »
Unfortunately I don't any spare boards to test with and I am getiing tired of buying spare test boards. Lately everytime I buy a spare or a replacement part I end up fixing the broken one without the need for the other one at all. >:(
I would rather purchase a working AR III board, than try and hunt for a place that will sell me this resistor without having to buy 50 or pay $10 in shipping.
« Reply #8 on: August 09, 2006, 03:19:28 pm »
What it means is that the 10.3V is unregulated at the source.  It could be 11v, it could be 18v.  It gets regulated down at the destination by something like a voltage regulator, some resistors, etc.  The destination board's input is what does the regulating, not the source board's output.
