Author Topic: AtomicFe questions????  (Read 1072 times)
divemaster127
  • Trade Count: (+60)
  • Last login:December 02, 2018, 08:05:08 pm
  • My webstore is arcadeemulator.net
    • arcadeemulator.net
« on: August 07, 2006, 12:48:13 pm »
Great front end, the preconfigured emu. are great, daphne has always been a pain to setup a few questions...
1. the mame precon. what version would that be .107 etc, is it equivalent to a command line...
2. For mame im just pointing just my mame setup, i noticed on the preconfig. mame it puts the games into racing, fighting etc, can you setup this up with just pointing to regular mame & is so how do you do it, great frontend, im still setting up awesome frontend, with the new preconfig. programs that's a lifesaver for setting up everything
thanks
dm
I carry both ultimarc & happ items, all brand new & I ship from the united states. My online store is ARCADEEMULATOR.NET, pm if I can help in anyway.
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
Re: AtomicFe questions????
« Reply #1 on: August 07, 2006, 01:57:05 pm »
Hi, Thanks.
Mame version in Modules are :
For MAME_youki1  module , it is a  build based  on version 0.102  .  (but generally by just changing the .EXE (and renaming it the same name it was in the module)) you can update your mame version.
AngelCry arcade modules are based on a 0.105 build i think.  (but that modules includes Zinc and Modula2 , and run games on the best emulator)).
If you don't want category, you can try AngelCry_arcade modules (NOT the Enhanced one).
Or of course you can make your own configuration :  (I suppose you want keep plug'n play modules active next  your own config)
-Open AtomicManager.exe
-Go on the "folder" tab , Make point the ROMS folder to your Roms folder , the SNAP ones too and others if you have some.
-Make point the Default Emulator Field to your Mame.exe  (or Mame32.exe) or what you have as emulator.
-Click on Save.   give a name (ex :  MyMame.cfg )  .
Then go on the "Tools" tab
-Click on the last button " Run Plug'n Play Manager Module wizard"
-Click on "Add an existing config" button (at the buttom of the list)
-In the field "config file to add" , select your "MyMame.cfg"  you saved previously
-In the field "picture associated", select a Png file to illustrate your config (if you want)
-In "displayed name "  , select the text you want  see for your configuration in the Module Selector menu.
Then exit, and run Atomic.
You should see your new menu , enter in it, and you should be able to run your own mame config.
