Author Topic: Width of control panels?  (Read 2788 times)
Justin
  • Last login:January 08, 2026, 10:28:19 pm
    • Centipede MAME cabinet
« on: March 13, 2003, 11:27:24 pm »
Does anyone know what would typically be the width of the control panel on a classic cabinet?  (Not a protruding c.p. like most MAMERs have).
So, for example, cabinets like Galaxian, Stargate, etc.
"3 warps to Uranus" -- so I stopped playing!
anthony691
  • Last login:January 29, 2016, 03:10:23 pm
    • Lightgun.tk
Re:Width of control panels?
« Reply #1 on: March 13, 2003, 11:31:10 pm »
I have a JAMMA cab (so not too clasic) it is 8.5x24.
Visit my MAME lightgun site:
http://www.lightgun.tk
Justin
« Reply #2 on: March 13, 2003, 11:35:17 pm »
Crap.  I was hoping for 28x10.    I won't be able to fit everything I want in a 24x8.5.
I really don't want a protruding panel... want to keep the classic look.  But I also want a gutted cab.  Looks like I'm gonna have to Build My Own     :-\
TacoSmuggler
  • Last login:March 30, 2017, 06:35:45 am
« Reply #3 on: March 13, 2003, 11:39:20 pm »
There is no 'standard' size fo cabinets. It depends on the make of the cab. For example...My Cp on the cab I am making into mame (xenophobe cabinet) is 27.4" by 14.3"
If you know what the make of the cab is we could help you out better.
Sanity leaves too many walls to bounce off of
While the deranged can run endlessly in any direction they choose
spidermonkey
  • Bombjack junkie
« Reply #4 on: March 14, 2003, 01:16:32 am »
Thats why alot of us have such large control panels. (commonly referred to as "Frankenpanels" ::). You just can't comfortably fit joysticks,a trackball,spinner,trigger stick and a butt load of buttons on a normal size classic control panel. More controls = more real estate. Thats one of the reasons I built my own cab. Its slightly taller and wider then an average arcade cab. This way the oversized control panel doesn't dwarf the cabinet and look quite so rediculous. Other solution is build a series of swappable panels. Oh yeh, "1UP" has quite a solution too.
"Sinistar has bad breath"
Odonadon
  • Last login:January 27, 2006, 12:01:12 am
  • But then again, that's just one man's opinion.
    • Turbo2k
« Reply #5 on: March 14, 2003, 01:25:38 am »
I believe you've come to the right place if you wanted to build your own arcade controls  ;D
K, bad joke.
Odonadon
It's Captain Odonadon, and his magical bag of nuts.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #6 on: March 14, 2003, 03:29:13 am »
Approx 24" for two player games, usually AFAIK.  A classic standup Pole Position has ~25" outside to outside cab walls width (so space for ~23.5" control panel to fit between the walls, or 25" if it sits on top).  I have a ~22" control panel for two player baseball with those snap analog joysticks.  One player classic cabs feel smaller to me, but I think it's partially because the smaller monitor is usually recessed, so you lend into the cab to get see better.
I think I'm going to model my cab off a pole positon cab, but widen it just a bit so the inside to inside width is 24" to fit my control panels I already made, as well as a original pole position CP and (hopefully) a championship sprint CP (also 23.5" wide).
As you see, I plan on going the swappable CP route, so I won't need 42" wide control panels, and I prefer the look of flat wall cabs, without over-hanging control panels.  Of course, this will make a 4 player CP harder to fit in there... ;D
Robin
Knowledge is Power
« Reply #7 on: March 14, 2003, 07:32:50 am »
I too am not really keen on overhanging control panels.  I am basing the width of mine on what I can fit through a door.  I think UK door frames are usually 30" wide, but to fit through comfortably I think I am going to make mine 60-64cm wide.  I am planning to rougly copy the Atari System 1 design, which I believe is 64cm wide.  Of course to fit all the controls I want I will have to build about 4 swappable panels (1UP's great idea is beyond my skills!)
http://www.arcadeflyers.com is a good place to look for cabinet sizes - often the deimensions are stated on the original flyer :)
Justin
« Reply #8 on: March 14, 2003, 08:08:32 am »
Oh, wow.  I never noticed the dimensions were in the flyers!  Thanks so much for pointing this out.
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #9 on: March 14, 2003, 10:02:14 am »
How wide does a panel need to be to fit two joysticks (perfect 360s) with a street fighter/neo geo 7 button layout and a trackball between the two.  Please say 26 - 27" will do the trick.  I am referring to a classic style cab without an overhanging control panel.
Best Kid iPad Apps
DeathMonk
  • Last login:April 03, 2015, 02:01:12 pm
    • MameStation.3
« Reply #10 on: March 14, 2003, 10:06:43 am »
That should do the trick..  My CP is HUGE for only having 2 player SF-like layout, but it doesnt need to be..  Take a look at some examples and you will see that there are many different sized cp's with the sf layout...  It's all about personal preference.
Now with cup beer holders!
Jungle
  • Last login:March 05, 2006, 08:38:19 pm
« Reply #11 on: March 14, 2003, 10:23:27 am »
That is about the size of my prototype panel.  I found it workable but a little tight for my liking.  The biggest problem I had was hitting the player 2 joystick while playing Golden Tee PC.  If you aren't going to be playing an trackball games where you really need a lot of room for wild swings, it should be OK.
OSCAR
    • Oscar Controls
« Reply #12 on: March 14, 2003, 11:42:18 am »
Check out Zakk's projects at http://www.mameworld.net/massive/ for some good examples.  Zakk uses mostly classic style cabs and the original control panels.
Chris
    • Chris's MAME Cabinet
« Reply #13 on: March 14, 2003, 12:07:05 pm »
Mine is 23"x7", in what was a Super Contra cabinet.  Two-player layout with 4 buttons per player and a trackball with 2 buttons in the middle.  (I removed the spinner; it was in the way of the trackball.)
The panel is removable, and I may create a second panel with an analog stick, a 4-way stick, and a spinner.
--Chris
--Chris
