Author Topic: Quick Mala Question  (Read 4155 times)
sportswizdan
  • Last login:April 05, 2012, 02:13:39 am
Quick Mala Question
« on: August 05, 2006, 01:59:44 am »
Hi...
Ok, I got Mala working pretty much with all my emulators and I am learning more as I go through it. I just need to learn a few "tweaks" to make sure I have everything running properly. My question here is if I run Mame32 without using Mala, and have the filter set for "working games" it comes up with 5453 games. If I run Mame32 thru Mala, with the exact same filter, it shows 5125. Thats a 328 game difference. I just want to be sure that I am not missing any working games thru Mala. Can someone tell me why there is such a difference in games or what I should have this "setting" set at in Mala? Thank You
Dan :cheers:
loadman
  • Moderator
    • MaLa
Re: Quick Mala Question
« Reply #1 on: August 05, 2006, 02:27:17 am »
Is Mame32 and mame the same version number?
sportswizdan
« Reply #2 on: August 05, 2006, 03:11:50 am »
Im only using Mame32 and it is version 0.106. Thanks,
Dan
loadman
  • Moderator
    • MaLa
« Reply #3 on: August 05, 2006, 03:36:29 am »
I have never used mame32 filters before so I don't know what data it uses.
Does it use catver.ini (Genre) & controls.ini (Controls) like MaLa does?
Please describe what filters you are using.
unclet
« Reply #4 on: August 05, 2006, 05:26:52 pm »
Sounds like a question for Swindus   :)
