Author Topic: mala and mame107  (Read 7738 times)
philby85
  • Last login:August 28, 2008, 08:25:17 pm
mala and mame107
« on: July 29, 2006, 02:15:59 am »
Hi All,
Set up mala works great! Installed mame 107 and roms works well. However when in mala i try and configure mame so that it skips the disclaimer,game info and validation check. None of these settings are written to mame.ini when i exit. i have e-installed mala, tried mame106 ans mame32.
cheers
Phil
loadman
  • Moderator
    • MaLa
Re: mala and mame107
« Reply #1 on: July 29, 2006, 02:23:01 am »
Hi All,
cheers
Phil
Not sure if you can change that in the latest versions anyway. I have seen a few posts
Have a look at you mame.ini to see if you have that option
I use mame .89 and all is good for me
philby85
« Reply #2 on: July 29, 2006, 02:34:49 am »
cheers loadman.
after reading those others posts i'm expecting a flame or two!  :-\
loadman
  • Moderator
    • MaLa
« Reply #3 on: July 29, 2006, 03:50:02 am »
If you check at mame.net I'm sure you can find out when they changed things. You could try using an earlier version (if your roms work with it)
loadman
  • Moderator
    • MaLa
« Reply #4 on: July 29, 2006, 07:19:48 pm »
Glad to hear most of your games are working now (you told me via PM)
If you are feeling confident you can sort out your roms for the mame version you are using via this app:
http://www.clrmame.com/clrmame.htm
payment_due
  • ---Probation---
  • Last login:August 19, 2012, 11:04:24 pm
  • ---Probation---
« Reply #5 on: July 30, 2006, 11:27:37 am »
Hi All,
cheers
Phil
I had this problem, but I would change them manually in the mame.ini file, but when I ran MAME it would overwrite my changes, it really pissed me off.  What I did is open the mame.ini file, make all nessecary changes (skip_disclaimer, skip_gameinfo, confirm_quit etc) and save the ini file.  Then, right click on the file itself, and click on properties.
Make the file READ ONLY and MAME won't be able to override any changes you made.    Maybe that will help.
my MAMEcab progress blog: http://www.lealmedia.com/mame/
bleemus
  • Last login:September 01, 2016, 12:53:24 pm
  • Party Pengo in the house.
« Reply #6 on: July 30, 2006, 01:39:50 pm »
This is off topic from the original post, but the last few posts have been about this:
Mame32 will rewrite your ini file every time you go into the options.
I have edited and compiled a version of .107 MAME32 with the skip options in the mame source and also available in the options UI so you can use the options freely.  If anyone wants it, PM me with an email address that can take at least a 12MB attachment.  I will send you the P4 optimized version unless you tell me otherwise.
Reality is overrated.
philby85
« Reply #7 on: August 01, 2006, 01:16:41 am »
Thanks everyone! I tried what punjabee said and it works! Damm should have thought of that myself.
philby
philby85
« Reply #8 on: August 01, 2006, 05:39:29 am »
Well seems as if I was talking out my butthole yet again :-[ It worked with version 103, but not 107.
philby
loadman
  • Moderator
    • MaLa
« Reply #9 on: August 01, 2006, 07:21:23 am »
ok Which specific settings are not working for you in mame 107 but are working in mame 103?
When you tell me I will try it myself
« Last Edit: August 01, 2006, 07:52:05 am by loadman »
philby85
« Reply #10 on: August 01, 2006, 08:25:27 am »
Hey loadman,
not working are skip disclaimer and skip validationcheck.
cheers
philby
Chris
    • Chris's MAME Cabinet
« Reply #11 on: August 01, 2006, 08:54:07 am »
These settings were recently removed from MAME.
--Chris
loadman
  • Moderator
    • MaLa
« Reply #12 on: August 01, 2006, 09:19:44 am »
Sorry Dude,
Not a MaLa issue as I suspected with my first post
