Author Topic: crashes when pressing clearqueue button  (Read 3644 times)
lurkio321
  • Last login:July 18, 2013, 10:38:25 am
« on: July 27, 2006, 12:42:44 pm »
Hi
been using wincab for a while, and must say it's an excellent program.. however i've hit a little problem...
i've assigned key a to the btn_clearqueue command but when it's pressed wincab crashes with  a windows error report... i've tried the latest version with the same results... i've checked the debug log and it only shows the last song to be added
any suggestions
Chris
  • Moderator
    • Chris's MAME Cabinet
Re: crashes when pressing clearqueue button
« Reply #1 on: July 27, 2006, 01:12:25 pm »
Hmmm... seems like I've seen this before... do you have MaxQueueSize set to a really low number?  The maximum queue size used to be hard-coded to a high number, so if I have a bug here this would be the most likely reason...
--Chris
--Chris
lurkio321
« Reply #2 on: July 27, 2006, 01:58:50 pm »
max queue size is set at the default 500...  i've tried adding just 2 or 3 songs to the queue and pressing the clearqueue button,  it's not really important. but my wife and i tend 2 have a few parties and people load up loads of songs into the queue and pressing the skip button can be time consuming when ur song is at song 25
Chris
  • Moderator
« Reply #3 on: July 27, 2006, 02:08:00 pm »
I'll check it out tonight and see what I can do....
--Chris
--Chris
jp
  • Last login:May 23, 2007, 11:23:54 am
« Reply #4 on: July 27, 2006, 03:24:47 pm »
have the same problem at parties i just set maxque to 5 (really low ! )so only 5 songs can be selected
only problem here is that if nobody ads songs  the que gets filled with one (same ) song
so i have to tell them to ad songs regularly (or or raise maxque,and wait for the favorite one)
for skipping songs (they are someones favorite,else he wouldn't have selected it) i didn't assign a button
(no songs are skipped)
« Last Edit: July 27, 2006, 03:29:06 pm by jp »
Chris
  • Moderator
« Reply #5 on: July 27, 2006, 10:48:57 pm »
I've fixed this problem, the fix will be in the next release.
--Chris
Chris
  • Moderator
« Reply #6 on: July 27, 2006, 10:52:00 pm »
Looking for this bug now; in the meantime, set PlayStimulatorDelay = Disabled in jukebox.ini to keep the queue from filling with a song.
--Chris
Chris
  • Moderator
« Reply #7 on: July 27, 2006, 11:21:16 pm »
I think I have this one fixed as well; the fix will be in the next release.
--Chris
jp
« Reply #8 on: July 30, 2006, 03:49:08 am »
 tried the b9-version ,
looks like these items are fixed
thanks a lot
« Last Edit: July 30, 2006, 03:53:09 am by jp »
