Author Topic: Mamewah: mame 106 and joystick  (Read 1426 times)
xfactor
  • Last login:June 25, 2007, 01:56:13 am
« on: July 24, 2006, 10:42:45 am »
Hi guys!!
I've a problem with mamewah and mame106: My cabinat use 4 usb joysticks..and here is the problem: how can I enable joystick input in mame command line version? if is not possible how can I configure mame.ini in mamewah to work with mame32?
Unkis17
  • Last login:March 24, 2017, 12:03:37 am
  • I'd keep on building if i had the space
Re: Mamewah: mame 106 and joystick
« Reply #1 on: July 24, 2006, 11:45:07 am »
If I understand your problem correctly then all you need to do for a joystick to work correctly in mame is modify the mame.ini file.  There is an input section, a line for keyboard, mouse and joystick.  Make sure you have joystick enabled (value=1).  This will allow a joystick to work.  As far as Mamewah goes, I know in version 1.62b10 in the Mamewah.cfg file you need to do a similar thing and enable the joystick.
If you are using a keyboard type encoder then all the buttons should work in mamewah right off the bat, otherwise you need to write in the JoyCode_1_Button# in the mamewah.cfg to program Mamewah react accordingly.
Make sense?
xfactor
« Reply #2 on: July 24, 2006, 12:38:36 pm »
The only mame.ini I have is in the mamewah\config folder...
no mame.ini in mame folder...
xfactor
« Reply #3 on: July 24, 2006, 01:03:57 pm »
Problem fixed: I have dowloaded mame.ini. After I put it in the mame folder and edit it. Now Joy works! But here another question: Is it possible to remove the game information screen that I see when I lunch a game? I know this is possible with mame32..what about mame command line version?
thanks
