Author Topic: Virtua Arcade 2  (Read 3062 times)
phantax
  • Last login:April 30, 2012, 07:12:14 pm
Virtua Arcade 2
« on: July 24, 2006, 12:16:04 am »
So, I have had this Sega Model 2A / Virtua Fighter 2 board sitting in a generic cabinet for a while and it really deserves a proper home. To my suprise, an empty VF2 Cabinet with coin door, control panel and glass went up on craigslist.
Being several hours away from the seller, I asked a friend who lived near the seller and just so happened to be headed my way the next day, to pick up the cabinet for me. I could tell by the pictures on craigslist there was some damage to the bottom, no big deal or so I thought. If I would have had the chance to inspect the cabinet before purchase, I likely would have changed my mind as there was pretty bad water damage to the back and bottom of the side panels.
Upon receiving the cabinet I had thoughts as to just scrap it, but it was already in my possession so we might as well break out the tools and see what we can do.
The bottom was practically falling apart, as well as the back of the cabinet. There was also numerous chips to the laminate around the edges of the cabinet.
First I peeled off the side art to see what kind of discoloration I was dealing with. Basically a totally different shade of gray. The art wasn't in too bad of shape but had cigarette burns and other tears so it was scrapped.
Time to start on fixing the bottom of the side panels. The 'wood' practically crumbled off, but I used a saw anyways. Cut off 4 inches from the bottom of each side panel.
The bottom panel was attached to the side with 'Dadoes' - So I broke out the router and cut a groove in the new 4" strips I cut to repair the sides.
The new pieces were attached with wooden dowels and glue, as well as a support piece I cut from a spare board that was screwed to the inside of the top and bottom of the seam. Here is what it looked like when I finished that.
The access panel on the back was completely shot, as well as the bottom piece of the back. I could have put my hand through the wood it was so soft. I wanted to add a hinged access panel anyhow so I basically made a whole new back, excluding the upper piece.
This was also attached with 'Dado's' so I had to route out another groove for the bottom piece as well as cut slots for the wheels to fit in. It would have been a simple job for a flush trim bit on the router but the part I was replacing was so bloated it was impossible, so I just cut it by hand.
The cabinet was given a sanding with 80 grit to remove some existing paint on the top back panel as well as to give the existing laminate a bit of a rough surface for the paint to stick better. One coat of "Gripper" primer has been put on, which adheres to the laminate quite well and doesn't seem to scratch.
After the primer dried, I filled all of the countersunk screw holes and chipped edges with 'plastic wood' filler, which I have never used before, but seems to work quite well.
I am going to let the filler cure overnight, give it another sanding and coat of primer then decide what to do from there. I have put in a few requests to people who claim to be able to get Virtua Fighter 2 NOS side art, but if that proves to be too expensive the cabinet will get a coat of black paint and probably end up as a Mame cab with a theme I haven't quite decided on yet.
« Last Edit: July 31, 2006, 06:29:46 pm by phantax »
phantax
Re: Virtua Arcade 2
« Reply #1 on: July 25, 2006, 02:18:32 am »
Well, I got prices back on Virtua Fighter 2 side art and its more than I am willing to spend for it. The art just isn't that great anyhow so my VF2 will go on living in its generic cabinet. So I gave it a sanding and a coat of black.
I have to say the "Plastic Wood" filler amazed me, You cannot even tell where the missing and chipped laminate was once the paint went on. I can still see a few dimples where there are some screw holes so Ill fix those up and sand again before the next coat of black.
I didn't bother fixing the laminate that ripped off the bottom of the front panel as the original cabinet had grip tape as a kick shield on the bottom 4 inches so I am just going to put new tape on, I like the way it looked anyhow. I also am not going to paint the inside as it is already laminated.
The black paint shows a few imperfections I couldn't really see with just the primer on, so I am going to fix those up before the next coat as well.
I have decided to go with a black / green color scheme, so I ordered 40ft of green t-molding which should arrive later this week.
« Last Edit: July 31, 2006, 06:30:33 pm by phantax »
  • Last login:Yesterday at 04:50:43 pm
Re: Virtua Arcade 2
« Reply #2 on: July 25, 2006, 03:26:03 pm »
It's really looking great so far - you did a nice job fixing the wood damage.  Keep us posted!
phantax
Re: Virtua Arcade 2
« Reply #3 on: August 02, 2006, 01:17:42 pm »
Finished up the painting. Applied the kick plate / grip tape and got the T-Molding on.
Now time to make a control panel I guess. Going to try to get ahold of a friend that does metal work and see if he can duplicate the VF2 control panel or fill in the holes of the old one and punch me some new ones. If that fails, it will be made of wood.
Elastikman
  • Last login:September 01, 2006, 10:35:34 am
Re: Virtua Arcade 2
« Reply #4 on: August 02, 2006, 07:25:17 pm »
Nice work!! :)
If i was me, i keep the light color... but its not bad the dark color too..
dudebozo
  • Last login:February 17, 2007, 03:06:38 pm
Re: Virtua Arcade 2
« Reply #5 on: August 03, 2006, 09:00:58 pm »
definitely coming along great phantax.  good job, keep it up.  your cabinet sure has came a long way.  good stuff
this bozo thinks, so therefore he definitely is a bozo
phantax
Re: Virtua Arcade 2
« Reply #6 on: August 18, 2006, 12:05:23 am »
Not much new to report, waiting on parts to arrive and looking for some free time to create graphics for the Marquee and Control Panel Overlay.
I did get the control panel blank back from my metal guy today so in the interest of keeping this project updated I will post pics.
Gave him the Virtua Fighter 2 metal control panel and asked him to duplicate a blank for me. He did a really nice job and made it out of stiff aluminum so its not as heavy as the original - cost me $35.00
After the CPO is applied he will punch the holes for me as well.
Here's the original CP
And the Aluminum blank he made
