February 04, 2026, 06:39:37 am
Have you considered replacing the microswitches?
Only other option is when you checked by using other grounding, did you use grounding that was wired straight into the end? (i.e. connect the grounds directly with a ground coming off the pc power supply?)Are all the grounds in one big loop, or do you have multiple series of loops?
...If I hit keys connected to the ipac 10 times I get either 10, 9 or even 8 key presses some times.
Does it make a difference if you press and hold for a moment vs. tapping the buttons?
