Author Topic: Need help with Windows XP boot issue  (Read 1491 times)
fatfingers
  • Got UltraStiks?™
« on: July 22, 2006, 07:48:54 pm »
I installed my Dell Dimension 4300 from scratch with Windows XP.  Not XP SP2 or even SP1, XP.  Yes, I did install updates after I got network connectivity.  Everything seems to run fine, but I have one issue at boot time.  Instead of just booting right into Windows XP, I am given a screen in which I have to select one of two OSes (both of which appear to be identical Windows XP choices) in 45 seconds or the first one will boot by default.  Needless to say, I don't want this boot screen to show up and I just want it to boot into the XP that I installed.
Is there any way to get rid of that prompt and if so, how would I fix it?
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
vulcanfk
  • Last login:August 11, 2006, 04:05:43 pm
Re: Need help with Windows XP boot issue
« Reply #1 on: July 22, 2006, 08:06:11 pm »
is the windows xp that you boot into selected by default?
if so, load windows.  click start->run and type in 'msconfig' (without the quotes).  click on the 'BOOT.INI' tab. in the middle-right of that window, change the timeout to 0 or 1 second.  click ok (or apply, then ok).  reboot.
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
« Reply #2 on: July 24, 2006, 07:50:11 am »
Or, you can try that  , (almose the same thing that vulcanfk , but by hand)
Open your file : BOOT.INI   (on the root of c:\ usually , but maybe hidden)
You will see something like :
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(1)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(1)partition(1)\WINDOWS="Microsoft Windows XP Professionnel" /fastdetect /noguiboot
multi(0)disk(0)rdisk(0)partition(1)\WINNT="Microsoft Windows 2000 Advanced Server" /fastdetect
Remove the unwanted row in the operating systems  section.
Set the timeout to 0  .
Check that the Default , point to the right config.
I strongly suggest you backup your file boot.ini before.
fatfingers
  • Got UltraStiks?™
« Reply #3 on: July 24, 2006, 09:19:18 am »
Thanks for the replies!  I think I will give youki's advice a shot.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
jcrouse
    • CPViewer
« Reply #4 on: July 24, 2006, 01:43:19 pm »
Sounds like you did not reformat and start from scratch. It retained your old pointer in the boot.ini file and then added a new one for the new install.
John
fatfingers
  • Got UltraStiks?™
« Reply #5 on: July 24, 2006, 02:40:10 pm »
John
Interesting.  Who knows what I did or did not do in my sleep deprived state that night.  :-(
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
