Author Topic: Sanding Discs in the 400 grit!  (Read 3896 times)
rdowdy95
  • Last login:July 29, 2011, 11:48:50 am
  • This is my rifle.
« on: July 21, 2006, 05:05:31 pm »
Anyone know where to get very fine aka 400 grit sanding discs.  All I have found are the 200 kind that are like fine sanding discs.
Re: Sanding Discs in the 400 grit!
« Reply #1 on: July 21, 2006, 05:27:51 pm »
I think that vey fine sanding discs (i'm guessing for an orbital sander) are harder to find because generally extremely fine sanding is done by hand or with a specialty sander, but I would check around automobile bodywork sources for very fine sanding stuff
NightGod
« Reply #2 on: July 21, 2006, 11:18:33 pm »
I picked up a cheap 1/4 sheet sander at Aldi for $5 and some 400 grit paper. It's not as convenient as the orbital sander, but it's a hell of alot better than doing it by hand.
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #3 on: July 23, 2006, 12:35:49 am »
Where do you live?  City & State.
Maverick
  • Last login:August 09, 2006, 09:53:19 pm
« Reply #4 on: July 27, 2006, 07:10:06 pm »
www.grizzly.com You can get them up to 1500 grit.
NightGod
« Reply #5 on: July 27, 2006, 11:44:29 pm »
Holy crap-isn't 1500 grit known as "masking tape"?
nostrebor
  • Not enough wit to effectively use this space...
  • Last login:October 04, 2013, 02:02:41 pm
  • SHOCKING!!
« Reply #6 on: July 28, 2006, 02:15:30 pm »
Auto body supply stores are a good bet. 5" disks might be harder to find though... AB paper usually runs 6" & 8".
« Reply #7 on: July 28, 2006, 02:34:15 pm »
Couldn't he just get the larger size and cut it down?
rdowdy95
  • This is my rifle.
« Reply #8 on: July 28, 2006, 10:11:58 pm »
A town in north texas.  I can get either the adhesive or the hook kind.  I bought some 250 fine grit stuff.  I am looking for some very fine 400 grit though.  I will check the website called grizzly.
