Author Topic: Drill size for button & joy  (Read 5873 times)
kalkin
  • Last login:January 20, 2004, 02:33:51 am
  • I'm an arcade builder wannabe!
« on: March 12, 2003, 02:12:56 am »
I know it's been asked before but I can't seem to find it using search.
What size drill do I need when drilling holes in cp for buttons and joysticks (supers, if it makes any difference)  ???
TacoSmuggler
  • Last login:March 30, 2017, 06:35:45 am
Re:Drill size for button & joy
« Reply #1 on: March 12, 2003, 02:18:43 am »
Just drilled out my overlay this week. Standard button size(from happs) is 1 1/8"
It was tough for me to find a hole saw that exact size but after a little searching I found a whole mess of em at Sears. None to be found at Loews or Home Depot. Hope this helps.
Sanity leaves too many walls to bounce off of
While the deranged can run endlessly in any direction they choose
bloodyviking77
  • Last login:March 07, 2010, 07:01:38 am
« Reply #2 on: March 12, 2003, 04:36:01 am »
You can also use a 1 1/8" spade bit - though they can be a bit pricey.
Shut up! Bloody Vikings!!
kalkin
« Reply #3 on: March 12, 2003, 05:57:01 am »
Thanks a lot! I needed the size, however, living in Sweden I don't have access to the stores you mentioned.
1 1/8" (1.125"). That's about 28.5 millimeters for us metricians. Hm, sounds like an odd size.
What's the difference between using a spade bit and a hole saw anyway? A hole is a hole is a hole, right? :) Sorry if it's a silly question, it's just that I've never done serious woodworking before.
After searching I found this adjustable spade bit, which would possibly deal with the awkward size problem....
http://www.clasohlson.se/images/products/S/hi/A/HD3_307760_hi_S.jpg
Think it might work?
bloodyviking77
« Reply #4 on: March 12, 2003, 07:10:19 am »
yeah a hole is a hole pretty much - I'm no woodworking expert though.
Dunno about the adjustable bit - May work Ok.
I bought a spade bit because I could buy it on its own (whereas hole saw bits come in sets). I'm in Australia, (metric system too  ;D) so I'll check the bit out and see if it gives a metric size equivalent or "number" and post it again later.
ErikRuud
  • Last login:March 05, 2021, 10:20:27 am
« Reply #5 on: March 12, 2003, 09:38:32 am »
A hole saw is like a cylinder with saw teeth on the end. A hole saw will usuually give better results. but the depth they can handle is a little limited. A hole saw is one of the few options for holes over 2 inches.
A spade bit is a flat blade with point on the end of a shaft. Spade bits can usually drill a deeper hole, but they are usually only made in sizes under 2 inches.
I used a spade bit on my with no problems.  One of the tricks to getting clean holes with either type is to drill your hole part way through on one side. Stop when the pilot bit(Hole Saw) or point(Spade Bit) starts to come through the other side.  Then complete the hole from the other side.
American Laser Games Wrapper
O2em Rom Utility
bionicbadger
  • Last login:October 01, 2012, 10:37:26 am
  • Big Deal
    • Mame Cabinet Page
« Reply #6 on: March 12, 2003, 10:23:56 am »
I used a 30mm Forstner bit since 28.5mm is kinda tough to find.  It worked great.  Its a tiny bit bit bigger than the 1 1/8" that everyone recommends, but only by about 1/16.  I used this cause it was in the set of forstner bits that already had and I didn't want to go out and buy another special bit.
If you are going shopping for a bit, I would get a forstner bit over a spade bit, it makes cleaner holes.
Silverwind
  • Last login:September 26, 2022, 12:49:09 am
« Reply #7 on: March 12, 2003, 10:27:17 am »
I used a 1 1/8" spade bit... it was speedbor brand from lowes and was about $5..
worked well on the wood.. you just have to watch for breakthrough..  the spade bit also worked well on the lexan.. very good results for the price!
djsting
  • Last login:July 22, 2015, 08:30:06 pm
    • My MAME Project
« Reply #8 on: March 12, 2003, 12:13:41 pm »
1 1/8" Forstner bit is the way to go.  You get a nice clean hole everytime.  I'm sure that if you are not in a hurry someone here may be willing to buy you one and send it to you as long as you cover the cost of the bit and shipping.  You could also buy one online somewhere probably.
kalkin
« Reply #9 on: March 12, 2003, 02:15:41 pm »
Thanks for all the replies :D
I bought one of those adjustable spade bits and I think it would have given a good result if the darned thing didn't wobble, giving the hole a slightly conical shape >:( Going to replace it and give it one more chance.
Anyone know if there's a recommended size for the hole for joysticks too? I'm using Happs Supers and the CP is made of 5/8" (16mm) MDF.
Kane
  • Last login:June 06, 2023, 08:05:47 am
  • What?
« Reply #10 on: March 12, 2003, 02:33:37 pm »
Use the same size holes for the stick as the buttons(1 1/8)
« Last Edit: March 12, 2003, 02:34:12 pm by Kane »
neuromancer
  • Last login:May 10, 2006, 04:26:57 pm
  • Can I Play?
« Reply #11 on: March 12, 2003, 02:42:06 pm »
If your CP is too thick, a 1 1/8 inch hole will keep the joystick from being able to move through it's full range. I use a 1 1/2 or 1 3/4 spade bit for the stick.
I find spade bits work much better than hole saws. But that's just me. I always flip the work over the moment the point on the bit breaks through.
Bob
anthony691
  • Last login:January 29, 2016, 03:10:23 pm
    • Lightgun.tk
« Reply #12 on: March 12, 2003, 04:31:30 pm »
I just drilled some CPs; i used a 1 1/8 spade bit in my drill press, it worked out really nice.
Visit my MAME lightgun site:
http://www.lightgun.tk
cdbrown
  • Bowowow
« Reply #13 on: March 13, 2003, 01:03:36 am »
I'm in Australia as well as BloodyViking77 and most of the bits have both measurements on them.  I got both the hole saw and the spade.  Have only used the saw and found it very easy to use with a normal drill.  I hole saw is just a hollow cylinder with cutting teeth around the both edge and a pilot drill bit in the middle.  Because of it's cylindrical shape it is very easy to keep straight.
Here is a pic of a hole saw and spade
http://home.iprimus.com.au/craigrb/images/tools.JPG
You'll notice the hole saw is 29mm.  The other good thing about the hole saw is that as you are cutting, it only needs to cut a one circle in the wood instead of having to scrap a hole in the wood like a spade would do.
Cheers
-cdbrown
Hellfromabove
  • Last login:January 08, 2020, 05:45:41 pm
  • Soundwave Superior, Constructocons Inferior!
« Reply #14 on: March 13, 2003, 11:49:27 am »
Just use a boring bit. They are very cheap and I use it for my arcade sticks. Very easy to use. Thanx.
-See Ya!!!
neuromancer
  • Can I Play?
« Reply #15 on: March 13, 2003, 04:05:30 pm »
The downside is getting the leftover plug out of the hole saw can be a pita.
If you have a drillpress, the only reason I can see to use a hole saw is sheetmetal.
Bob
TacoSmuggler
« Reply #16 on: March 13, 2003, 11:35:13 pm »
Bob
Actually I believe all hole saws have a notch(or many notches) along the bit itself that are designed to help in plug removal(from the bit). I know mine did. You simply take a nail or pencil and pop the plug out of the bit.
I made my 1st CP with a spade bit and will NEVER use it again. If you are not using a drill press it is too hard to keep straight. I had no problem with the hole saw though. To each their own I guess... ;D
kalkin
« Reply #17 on: March 14, 2003, 04:30:55 am »
Seems to be simply a matter of preference which one of the spade bit or hole saw to use. Nobody seems to have gotten a really bad result with either one. I'll be able to afford both once I return this wobbling, worthless, piece of junk adjustable spade bit I got :)
neuromancer
  • Can I Play?
« Reply #18 on: March 14, 2003, 02:17:25 pm »
Bob
Mine have notches too, but sometimes a plug of wood still gets stuck in there. Especially when I used it on oak. I ended up needing to drill holes in the oak an chip it out bit by bit. Took a long time.
I really like having a drill press. I have vauge memories of life before it, but I try to supress them. ;-)
Bob
medley
  • Last login:November 27, 2006, 10:23:05 pm
Advantages-Hole saw and Spade
« Reply #19 on: March 14, 2003, 02:26:59 pm »
I have found that Hole saws are easier to make a clean hole on  thiner material (like 1/8 lexan).
and Spade bits are faster for thicker material
(like 3/4 wood).
just my opinions.
ErikRuud
« Reply #20 on: March 14, 2003, 02:28:19 pm »
My Milwaukee hole saw has a quick release arbor(the part in the middle with the pilot drill) to allow for interchangeable blades.  I just pull the arbor out and pop out the plug with a screw driver.
Most other hole saws have some way to pull out the pilot bit.  That usually makes removing the plug a lot easier.
O2em Rom Utility
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #21 on: March 14, 2003, 07:56:18 pm »
It seems like Forstner bits aren't getting their fair share of discussion here.  They're like a combination of the best of both worlds between a hole saw and a spade bit.  They've been mentioned, but the debate seems to be focusted on spade bits v. hole saws.
my 2 cents
Best Kid iPad Apps
jon
  • Last login:March 15, 2003, 06:01:39 pm
« Reply #22 on: March 15, 2003, 06:02:50 pm »
what should i use to drill button and joy holes on 1/8 inch plexi?
any tips on doing it also?
shmokes
    • Jake Moses
« Reply #23 on: March 15, 2003, 06:36:44 pm »
Use a 1 1/8" forstner bit.  It drills the cleanest holes of the three bits and the lexan isn't as prone to melting as it is with the hole saw or spade bit.  Spade bits are especially notorious for causing melting in lexan as I understand it.  I've never actually drilled any lexan with a spade bit, though, so this is second-hand information.  Don't pick to many nits over it, though.  Remember that crappy button holes tend to look EXACTLY the same as nice clean button holes once the button is installed (the lip on the button will cover minor imperfections).  If you're on a budget just go with the spade bit and you'll probably be perfectly happy with the results.
Best Kid iPad Apps
TacoSmuggler
« Reply #24 on: March 15, 2003, 08:10:56 pm »
Shmokes is correct. Really whatever bit you use is cool. Your buttons will cover up any imperfections!
neuromancer
  • Can I Play?
« Reply #25 on: March 17, 2003, 02:47:48 pm »
They cost too much unless you *need* a flat bottomed hole. I've got one for some project I was working on, and it is excellent -- just too expensive.
My $0.02
Bob
Frostillicus
  • Arcade Artist
  • Last login:April 18, 2023, 07:36:29 am
    • My MAME cabinet site
« Reply #26 on: March 18, 2003, 01:13:16 pm »
My $0.02
Bob
yeah but you only need one for the whole cp project anyways.  And you can use it for the other CP's you will build (who can build just one? :) ) Besides-  Forstner Bit + Drill Press = Excellent and fast results.   I used one and someone asked if I had the cp machined because the holes are so clean and sharp - that's a pretty decent comment :)
Tiger-Heli
    • Tiger-Heli
« Reply #27 on: March 18, 2003, 01:32:53 pm »
For LEXAN, the follow-up answers are correct and most anything will work.
For PLEXI, most people recommend using a hole saw in REVERSE and lettting it melt instead of cut through the plexi.
neuromancer
  • Can I Play?
« Reply #28 on: March 18, 2003, 04:38:34 pm »
I used a spade bit, a drill press, and a jorgenson clamp for my plexi.
SAFETY GOGGLES are a must. Flying bits of plexi and eyes don't mix. Or I guess they *do* mix, and that's the problem ;-)
It worked fine.
Bob
Smittydc
  • Last login:October 05, 2008, 12:48:10 am
  • because its fun!
« Reply #29 on: March 19, 2003, 10:00:36 am »
Can't believe we've had 29 responses to this question.  Everybody: put down the mouse, step away from the computer slowly, and go outside.  ;D
<just joking, its great to hear different experiences>
Build a man a fire, he's warm for a night.  Set a man on fire, he's warm the rest of his life.
scooter
  • Last login:September 13, 2006, 09:57:01 pm
  • I want to build my own llama!
« Reply #30 on: March 22, 2003, 11:14:47 am »
Would a regular 1 1/8" boring bit be preferable to the others already meantioned?  I know my father-in-law has one (and yes, his drill press is HUGE--my back still hurts from when I helped him move it 3 years ago).  He has drill bits that take two hands to pick up.
-Scooter
Friends don't let friends buy iROMs.
Punchcard
  • Last login:August 31, 2003, 02:29:26 pm
« Reply #31 on: March 22, 2003, 01:49:02 pm »
Woodboring = spade bit
Frankly I used this without any problems, and chances are fairly good that you have them already your garage. Or maybe it was just me :)
