Author Topic: game launcher help!!  (Read 3479 times)
tyweed
  • Last login:March 09, 2008, 01:29:03 pm
« on: March 12, 2003, 12:11:47 am »
Hello i'm having alot of trouble with the initial config of mame in glaunch. i have set everything up correct in mame.cfg as far as i can tell? i have it in debug mode and it is showing when it tries to execute this
mame.exe .gaunt2
 it's putting a period infront of the rom command and i think that is the problem but i cannot get rid of it?
please if anyone has any ideas help!!!
romid
  • Last login:November 17, 2008, 02:33:12 pm
  • MAME rox your socks!
    • Temp MAME pics
Re:game launcher help!!
« Reply #1 on: March 12, 2003, 01:07:45 am »
in your mame.cfg file (inside the config directory of glaunch):
make sure you have the following set to "no":
# Use rom_directory when launcher game: "yes" or "no"
#  i.e. yes: "emulator.exe c:\full\path\rom"
#        no: "emulator.exe rom"
use_rom_directory = no
that should do the trick
tyweed
« Reply #2 on: March 12, 2003, 05:26:14 pm »
This is what i have.
directory- c:\mame065b\
exutable- mame.exe
use_rom_file - yes
use rom directry when launching - no
use ext when launching- no
list of possible ext - zip bin
dir to roms - c:\mame065b\roms\
options before rom - yes
i think i have everything right? if someone can send me there mame.cfg file that be great!
Odonadon
  • Last login:January 27, 2006, 12:01:12 am
  • But then again, that's just one man's opinion.
    • Turbo2k
« Reply #3 on: March 12, 2003, 05:31:26 pm »
mame.exe .gaunt2
I had the same problem when trying out Fastmame.  All I did was change the directory from "c:\mame" to "c:\fastmame" and the executable from "mame.exe" to "fastmame.exe".  And now it's throwing a "." in front of the ROM name.  I change the directories back, and it works perfect.  Change it back to fastmame, and it does that again.  Doesn't make any sense.  At all.  Has to be a glitch with Game Launcher.  All I did was rename everything "mame" to "fastmame" in the cfg file.
Odonadon
It's Captain Odonadon, and his magical bag of nuts.
tyweed
« Reply #4 on: March 12, 2003, 06:22:07 pm »
i fixed mine by going to use_rom_ext-no
romid
    • Temp MAME pics
« Reply #5 on: March 12, 2003, 07:23:37 pm »
You should try removing the trailing \'s
for example, change your "directory- c:\mame065b\" to "directory- c:\mame065b"
Also, when you do figure it out, be sure to post what it was so that we will know when/if other people ask
heres mine if it helps:
# Emulator name, i.e. MAME
name = MAME
# Short description of emulator, i.e. Arcade Machines
description = Arcade Games
# Location of emulator, i.e. c:\mame
directory = c:\mame
# Name of emulator executable, i.e. mame.exe
executable = mame.exe
# Global options passed to emulator, i.e. -sound 1
global_options = -skip_gameinfo -resolution 800x600 -hws
# Command to run before running executable. If blank, then nothing
# will be run.
pre_command =
# Command to run after running executable.  If blank, then nothing
# will be run.
post_command =
# Name of map file.  A map file maps short ROM file names to full game
# names.
map_file = mame.map
# Options go before ROM when launching: "yes" or "no".
#  i.e. yes: "emulator.exe -option1 -option2 rom"
#        no: "emulator.exe rom -option1 -option2"
options_before_rom = no
# Directory to look for screen shot images, i.e. c:\mame\snap
# Supported formats are PCX, PNG, and BMP.
screen_shot_directory = mame\snap
# A ROM file is a list of ROMs to use.  If set to "no", ROMs are
# scanned for in the rom_directory.  If set to "yes" a ROM file (which
# is essentially just a list of ROMs) is used instead of trying scan.
# The default is "no".  ROM files are useful for merged ROMs with
# MAME, where the actual ROM names are buried within a ZIP file.
use_rom_file = yes
# rom_dir, rom_extension, use_extension, and use_rom_directory are
# only relevant if a ROM file is not used.  They are ignored if not
# needed.
# Directory to ROMs
rom_directory = c:\mame\roms
# List of possible ROM extensions (without the ".")
rom_extension =
# Use extension when launching game: "yes" or "no"
#  i.e. yes: "emulator.exe rom.ext"
use_extension = no
« Last Edit: March 12, 2003, 07:25:31 pm by romid »
Distortion
  • Last login:June 10, 2016, 04:39:20 pm
  • Saints Row 2, Sucka
    • Volition
« Reply #6 on: March 18, 2003, 12:13:50 pm »
I had the exact same problem.  I still have the exact same problem.  That's why I'm using ArcadeFX.  I'd rather use GameLauncher, though.  I played around with every setting possible and got no good results.
Game programmers do not play games for a living.  Would you say a mechanic drives cars for a living?
Odonadon
    • Turbo2k
« Reply #7 on: March 18, 2003, 01:27:15 pm »
Exactly, same here.  Can't seem to fix the problems.  It doesn't make any sense - the only thing I changed was directory and the name of the exe file.  I'll play around with it this week and let y'all know if I find something that works.
Odonadon
  • Last login:Yesterday at 07:46:44 pm
« Reply #8 on: March 18, 2003, 03:25:00 pm »
Actually unless Dave has changed things again you should do the opposite and fill in any trailing backslashes.
Distortion
    • Volition
« Reply #9 on: March 18, 2003, 08:26:12 pm »
I've managed to get rid of the . before the games, but I have another problem.  The batch file seems to be coming out perfect, I run the batch file afterward and it opens the game just fine, but somehow the process crashes and the batch file is never launched.
Odonadon
    • Turbo2k
« Reply #10 on: March 18, 2003, 10:28:43 pm »
Care to share how you got rid of the . ?  :)
Wow, that's lots of punctuation...
Odonadon
Distortion
    • Volition
« Reply #11 on: March 19, 2003, 10:13:02 pm »
I don't remember, but it's not doing it any more.  I switched to MameWah.  It's working great for me, so I won't complain.
Odonadon
    • Turbo2k
« Reply #12 on: March 19, 2003, 11:51:10 pm »
Well, here's what I did:
I told mame.cfg to use full ROM path.  That didn't work:  I had my ROM files stored in c:\mame\roms\ and wanted to use fastmame from c:\fastmame\.  c:\mame\roms being the ROM path.  Kept getting the "." before ROM name.  Makes sense.
SO, I moved the ROMs to c:\fastmame\roms from c:\mame\roms, ran mamescan to make sure all was fine - problem solved :).  Good ol' Game Launcher.  Works like a charm.
NOT!  :)
And yet I continue to use it due to lack of a better product.  Weird how that works...
Odonadon
