Author Topic: Mamewah 1.62 10b and zinc  (Read 3732 times)
xfactor
  • Last login:June 25, 2007, 01:56:13 am
« on: July 19, 2006, 06:20:42 am »
Hi everybody!!! i'm becoming mad!!!
is there anyone that use zinc with mamewah 1.62 10b? I search in a lot of way but nothing...please help me :'(
Re: Mamewah 1.62 10b and zinc
« Reply #1 on: July 19, 2006, 07:07:03 am »
This is for v1.61 but with it should be pretty straightforward to convert with a few changes to zinc.ini:
http://www.mameworld.info/ubbthreads/showthreaded.php?Cat=&Number=22534&page=0&view=collapsed&sb=5&o=&fpart=1&vc=1&new=
xfactor
« Reply #2 on: July 19, 2006, 07:39:06 am »
I've follow your suggests but games still refuse to work. I see game list in mamewah screen but when I press 1 the don't start...
Congui
  • Last login:July 23, 2015, 12:54:53 pm
  • Newbie!
« Reply #3 on: July 19, 2006, 08:40:51 am »
Xfactor hi.
The problem with zinc is that it's based on an number asignation, instead of name asignation.  For example, in command line if you want to run street fighter (sfex) you type "zinc.exe  2" instead of  "zinc.exe sfex";  in this example I've omitted all the various swithes available.  It's important to get familiarized with zinc syntaxis through commandline first.
To be able to execute zinc from a frontend, there are several ways.  Howard has a wrapper that has had a lot success.  In my case, I wanted to find a solution of my own, which is why I made a quick VBS file (I've attached, along with my zinc.cfg; just remove the txt extension) that has to be in the same folder as zinc.exe.  To run the vbs in mamewah, all you do is modify the following option in your zinc.ini in the mamewah\ini folder:
emulator_executable                       d:\zinc\wrapper.vbs
This may not be the most elegant solution, but it works.  And remember, zinc just needs a bit of patience, however the end result is worth it.
Hope this works for you.
Cheers, :cheers:
Congui
« Reply #4 on: July 19, 2006, 09:14:02 am »
Did you follow all the instructions?  Try taking a look in mamewah.log after trying to launch a game and see what it says...
xfactor
« Reply #5 on: July 19, 2006, 09:42:55 am »
I don't find the wrapper...so i used the vbs..I tried putting zinc.cfg in the config/zinc folder.. but nothing work.
Here my Mamewah log:
19/07/2006 15.35.29 MAMEWAH v1.62 launched
19/07/2006 15.35.29 Cursor scheme: Predefinita di Windows, Arrow: (None), Wait: (None), AppStarting: (None)
19/07/2006 15.35.29 Desktop colour: 9981440
19/07/2006 15.35.29 Wallpaper filename: C:\Documents and Settings\Monica e Marica\Impostazioni locali\Dati applicazioni\Microsoft\Wallpaper1.bmp
19/07/2006 15.35.29 Display mode: 1024x768 @ 60Hz, 32 bit colour
19/07/2006 15.35.29 Decimal symbol: ','
19/07/2006 15.35.29 Games list read: zinc-0.lst
19/07/2006 15.35.30 Mode 640 x 480 @ 60Hz, 16bit colour selected after 2 attempt(s) at 1/2 second intervals.
19/07/2006 15.35.30 Layout selected: C:\Documents and Settings\Monica e Marica\Desktop\mamewah\config\layout.lay
19/07/2006 15.35.31 No. joystick devices attached: 0
19/07/2006 15.35.31 Ctrlr file selected: C:\Documents and Settings\Monica e Marica\Desktop\mamewah\config\zinc\zinc.cfg
« Reply #6 on: July 19, 2006, 09:47:50 am »
Read and follow my instructions, you do not need a wrapper.
You don't need zinc.cfg to set this up - you only need that which I have provided in the zip file.  You're overcomplicating things when there is no need to ;)
Congui
  • Newbie!
« Reply #7 on: July 19, 2006, 09:49:37 am »
Hi.
Do you have the zinc.cfg file in the same folder as your zinc.exe?
Cheers,
Congui
xfactor
« Reply #8 on: July 19, 2006, 10:11:02 am »
Maybe it's better if I told you what I have and where:
In Mamewah\ini\ I have zinc.cfg
In Mamewah\config\Zinc\ I have Zinc.ini and zinc-0.ini
In Zinc\ I have \cfg, \roms, \snaps, catver.ini, controller.znc, render.cfg, s11player.dll, sound.znc, wrapper.vbs, zinc batch MS-DOS, zinc.dat, zinc. nms
Congui
  • Newbie!
« Reply #9 on: July 19, 2006, 10:29:56 am »
Hi.
Move your zinc.cfg file to your Zinc folder; after all, this is file belongs to zinc and not mamewah.  You will also want to edit the file, once it's in your zinc folder, and change the following parameter to point where your roms are (I'm  using the same mame roms with no problem):
--roms-directory=d:\mame\roms\
Cheers,
Congui
xfactor
« Reply #10 on: July 19, 2006, 10:42:06 am »
I lunch a game and nothing...
the mamewah log say:
19/07/2006 16.43.20 emulator_executable:  does not exist in RunGame!
what is the meaning?
« Reply #11 on: July 19, 2006, 11:45:52 am »
Did you update the zinc.ini file for Mamewah v1.62?  Post the file if you want a hand....
Congui
  • Newbie!
« Reply #12 on: July 19, 2006, 11:47:19 am »
Hi.
Lets give it another shot.  Here's part of my zinc.ini:
### ZiNc.ini (mamewah v1.61) ###
emulator_title                            ZiNc
### List Generation Settings ###
rom_path                                  d:\mame\roms
rom_extension                             zip
dat_file                                  d:\zinc\Zinc.dat
nms_file
catver_ini_file                           d:\zinc\ZincCatVer.ini
list_generation_method                    rom_folder_vs_dat_file
### Execution Settings ###
commandline_format                        [name]{autodosbox}{nosafelaunch}
alt_commandline_format_1                  [name]{autodosbox}{nosafelaunch}
alt_commandline_format_2                  [name]{autodosbox}{nosafelaunch}
game_specific_config_path
I think the main difference (from seeing Minwah's ini file), besides the rom_path, is that he's using:
list_generation_method                    dat_file
while I'm using the:
If that doesn't work, then I'm clueless.  And believe me, that's the way I have it at home; it works for me flawlessly.
Cheers,
Congui
Congui
  • Newbie!
« Reply #13 on: July 19, 2006, 11:49:18 am »
Sorry, didn't ses your post Minwah  :-[.
Cheers,
Congui.
xfactor
« Reply #14 on: July 19, 2006, 11:51:22 am »
Have a look:
### Zinc.ini (mamewah v1.62) ###
emulator_title                            ZiNc
rom_path                                  D:\Zinc\roms
rom_extension                             zip
dat_file
nms_file
catver_ini_file                           D:\Zinc\catver.ini
list_generation_method                    auto:rom_folder
pre_emulator_app_commandlines
emulator_commandline                      D:\Zinc\wrapper.vbs
post_emulator_app_commandlines
general_app_commandlines
### Artwork Settings ###
artwork_image_paths                       auto:[emuexepath]\snap;[emuexepath]\titles;[emuexepath]\marquee;[emuexepath]\control;[emuexepath]\cabinet;[emuexepath]\flyers;[emuexepath]\boxart;[emuexepath]\cart;[emuexepath]\art9;[emuexepath]\art10
movie_preview_path
movie_artwork_no                          1
enable_fuzzy_search                       0
### Screen-Saver Settings ###
enable_music_in_screensaver               1
select_random_game                        0
saver_type                                slideshow
movie_path
movie_fullscreen                          1
quit_delay                                30
saver_commandline
### Additional Settings ###
music_path
lcd_display_file_path
### Settings used by MAMEWAH ###
current_list                              0
Now I lunch the game with 1 and after small time the screen return in the mamewah one
« Reply #15 on: July 19, 2006, 11:56:51 am »
Replace:
...with:
emulator_commandline                       d:\zinc\zinc.exe [name]{nodosbox}{safelaunch}
...unless you have to use the wrapper for some reason.  I have no idea what that wrapper is, and my method does not require a wrapper so I can only recommend that really.
xfactor
« Reply #16 on: July 19, 2006, 12:01:37 pm »
I launch the game but I fall in mamewah screen..can be a rom problem?
xfactor
« Reply #17 on: July 21, 2006, 12:28:43 pm »
Launching a zinc game from dos command line I recive the error: cannot open render plugin..si that's the problem!! Mamewah lung zinc and the application quit...
How can i make to open the render?Do I have ti configure it?
