Author Topic: Project Arcade marquee dimensions  (Read 3435 times)
greaser
  • Last login:December 21, 2007, 06:28:21 pm
« on: July 17, 2006, 03:04:38 pm »
What are the dimensions for the Project Arcade marquee? I plan on ordering a marquee from classicarcadegrafix.com and I'd like to know what size to specify.
gamecreature
  • Last login:October 29, 2008, 08:35:37 pm
  • I'm making this up as I go along.
    • Gamecreature
Re: Project Arcade marquee dimensions
« Reply #1 on: July 17, 2006, 03:29:37 pm »
I think it's a very good idea to physically measure the cabinet that you're trying to fit. Is there any reason that you cannot do this?
Make your cabinet look its best with custom art from
Gamecreature!
greaser
« Reply #2 on: July 17, 2006, 05:19:10 pm »
Well I've only just begun construction. I haven't quite reached the assembly portion yet. The reason why I'm asking in advance is that I have a limited amount of time to finish the cabinet before I move. I would have liked to know the dimensions in advance so that I'm not waiting around weeks for the marquee to arrive. I thought that if the cabinet was built to the specifications in the Project Arcade book that it would turn out the same as in the book, marquee included.
BlinKY1337
  • Last login:October 25, 2013, 11:06:36 am
« Reply #3 on: July 17, 2006, 05:46:21 pm »
Odds are its probably 26" X 7" possibly 7.5ish depending on your speaker shelf location. You should really measure its not to far into the construction that you will learn these dimensions.  :)
gamecreature
    • Gamecreature
« Reply #4 on: July 17, 2006, 05:49:49 pm »
I can understand your desire to get it done as soon as possible, but (depending on where you get it done) it usually comes pretty quickly - about a week or so. You could order it as soon as you cut the wood and it will very likely arrive as soon as your paint dries.
Just a suggestion. Unfortunately, I do not know the dimensions.
Gamecreature!
