Author Topic: Mamewah 1.61 or 1.62?  (Read 1617 times)
xfactor
  • Last login:June 25, 2007, 01:56:13 am
« on: July 16, 2006, 06:30:47 am »
I'm going to create my cabinet and I want to use different emultors: Mame, Zinc, Pj 64, Stepmania ecc..I decided to use Mamewah as frontend but I've to choose the 1.61 or 1.62 version...any ideas?
unclet
Re: Mamewah 1.61 or 1.62?
« Reply #1 on: July 16, 2006, 08:51:50 am »
I would always go with the latest version as it usually fixes a lot of bugs.  Especially knowing that MameWah 1.62 is up to offering a beta "11" release, I would not recommend sticking with v1.61   Jusy my opinion though.
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #2 on: July 16, 2006, 10:14:25 am »
[/too lazyto read the "whats new" file]
what are some reasons many are upgrading?  New features that you gotta have?
unclet
« Reply #3 on: July 16, 2006, 12:34:53 pm »
No idea ..... I think people say it is easier to set up.  I never used 1.61 so I can not say what is new.
Based on your first post, it made me think you were installing MameWah for the first time, rather than upgrading MameWah.  If I was installing something for the first time, I would simply use the latest version.  If I was upgrading (and it might be a pain to do so) then I would decide whether it was worth it based on the "whats new" file.
chemame
  • Last login:January 26, 2007, 01:54:05 pm
« Reply #4 on: July 16, 2006, 06:53:04 pm »
go with 1.62
it is certainly easier to set up than 1.61 (additionally, I found the 1.61 --> 1.62 conversion a little tedious and painful)
also, 1.62 has some features that, if they existed in 1.61, I never knew it... execution of pre-launch and post-launch applications, for instance. In 1.61, if I needed something to run before or after my emulator, I had to stick it all in a batch file, which got ugly and didn't always work as expected. With apps like AutoHotKey, I can easily launch scripts to catch and translate keypresses, etc... and the pre-execution launch makes this a breeze.
xfactor
« Reply #5 on: July 17, 2006, 03:25:32 am »
Where I can download Mamewah 1.62?
« Reply #6 on: July 17, 2006, 05:42:01 am »
Definately go with v1.62b10...although it is 'beta' it has less bugs than v1.61:
http://www.mameworld.info/ubbthreads/showthreaded.php?Cat=&Number=62689&page=0&view=collapsed&sb=5&o=&fpart=1&vc=1&new=1152870056
(for whatsnew just download the above and check the whatsnew.txt file)
Also while it doesn't look like it I am working on b11...just have a slight problem to get around and it shouldn't be too long until that comes out - configuration-wise it will be the same as b10 fwiw :)
xfactor
« Reply #7 on: July 17, 2006, 05:56:09 am »
