Author Topic: MaLa and LCD's  (Read 8448 times)
loadman
  • Moderator
  • Last login:January 29, 2026, 07:18:10 pm
    • MaLa
MaLa and LCD's
« on: July 14, 2006, 05:39:21 pm »
I have been so busy on the emumovies project that I have not had any time to install any other front ends.  I do have one question about mala though.  I use a 4x40 lcd to display the different controls used for different games/emulators.   MameWAH uses .lcd files to send instructions to the display.  Does Mala do the same thing?  The reason why it is so important is that I have spent countless hours creating those .lcd files for the different systems/games and it is not something that I could or would want to start over on.
You would have to do some work I would imagine.
Can you please send me your .lcd file for my own interest ?
MaLa sends the instructions/text on the fly to the lcd. You just have to create some line/screen templates with placeholder and MaLa will replace the placeholder for you when selecting/starting a game.
Here is the list of all placeholder (in german but I think you can understand) you can use:
Game values (Standard Mame Informationen):
- Buttons (~g_buttons): Anzahl der ben
« Last Edit: July 14, 2006, 06:13:35 pm by loadman »
Circo
  • Last login:May 11, 2020, 03:27:51 am
  • Still using screenshots? Try EmuMovies instead.
    • EmuMovies
Re: MaLa and LCD's
« Reply #1 on: July 14, 2006, 10:23:11 pm »
I am attaching an .lcd file for your review.  I use textpad to edit and create because it supports the ascii control codes that the display uses.  Mamewah just reads the file information and sends it directly to the lcd.  I will admit that it is a severe pain to create all of the files but it works great.  I added the .txt extension so that I could attach it.
Edit: I also am including the pdf of the manual, control codes are listed on page 3 if you are interested.
« Last Edit: July 14, 2006, 10:36:42 pm by Circo »
My Websites
loadman
  • Moderator
    • MaLa
Re: MaLa and LCD's
« Reply #2 on: July 14, 2006, 11:38:43 pm »
No .txt file appears to be there.    :(
Circo
    • EmuMovies
Re: MaLa and LCD's
« Reply #3 on: July 15, 2006, 12:43:20 am »
Its the 3 ninja's kick back link right above the first picture
My Websites
loadman
  • Moderator
    • MaLa
Re: MaLa and LCD's
« Reply #4 on: July 15, 2006, 01:00:42 am »
:banghead: I knew that. ......and thanks
You litterally have to make up the screen for every game do you?
Yeah MaLa is a bit more clever with the use of LCD. It's very similar to making a layout. You choose what 'fields' you want and where ,and then mala does the rest depending on what game you are playing or selected. Very quick and easy to set-up
I would say in your case... stay with what you have
1) Your LCD users a serial interface and MaLa uses parallel
2) "If it ain't broke don't fix it"
Thanks again for the info
« Last Edit: July 15, 2006, 01:08:13 am by loadman »
Circo
    • EmuMovies
Re: MaLa and LCD's
« Reply #5 on: July 15, 2006, 10:48:48 pm »
Any chance serial lcd support will ever be added to MALA?
My Websites
loadman
  • Moderator
    • MaLa
Re: MaLa and LCD's
« Reply #6 on: July 16, 2006, 02:49:06 am »
A question for SWINDUS but I say
Why would you bother when Parallel ones are so cheap. I bought two when I first started in case I blew one up   8)
LOOK HERE
Circo
    • EmuMovies
Re: MaLa and LCD's
« Reply #7 on: July 16, 2006, 02:58:44 am »
OMG Your right, um I see changes soon.  Wow thats cheap!
My Websites
Circo
    • EmuMovies
Re: MaLa and LCD's
« Reply #8 on: July 16, 2006, 03:23:43 am »
Ok I just ordered a couple of items  ::)  I just couldn't help myself!
The first thing is the insanely cool 6.4" LG TFT display, did I mention it was only $40!!!!
The second is another 4x40 display.  If I did decide to use Mala I wouldn't want my display just not work, and the different outputs are interesting.  And that was only $35, the one I use costs around $200 at seetron and it is the same thing???
Not sure yet how I will use the screen but I will find a way.  hehehe!
My Websites
gamecreature
  • Last login:October 29, 2008, 08:35:37 pm
  • I'm making this up as I go along.
    • Gamecreature
Re: MaLa and LCD's
« Reply #9 on: July 16, 2006, 08:15:12 am »
That definitely looks cool. Someday I'm going to put an LCD display in my cab, but I just don't have the cash right now (gotta sell more art!)
I've got a graphics card that supports dual monitors (including composite video). It would be cool to set up an LCD like the LG as a second monitor to show preview videos and game control input. :D
Make your cabinet look its best with custom art from
Gamecreature!
loadman
  • Moderator
    • MaLa
Re: MaLa and LCD's
« Reply #10 on: July 20, 2006, 07:49:15 am »
The LedWiz mod won't drive a 4x40 display (only up to 4x20)
To drive anything higher than that you need to use MaLa Hardware
