Author Topic: Joystick support in Mala RC7??  (Read 3967 times)
tk_42_1
  • Last login:November 17, 2010, 03:43:24 pm
  • I suggest a new strategy...Let the Yorkie win!!!
« on: July 11, 2006, 02:49:27 pm »
Moved from Mala RC6 to RC7 and all of a sudden my joysticks are not being seen by Mala.
I have two 49-ways running off of 2 GP-Wiz49s.  They work fine in MAME if I start the games with the keyboard through Mala.  They just aren't seen and everytime I check the "Use joystick" box, its unchecked when I go back into options.
Anyone have any ideas???
loadman
  • Moderator
    • MaLa
Re: Joystick support in Mala RC7??
« Reply #1 on: July 11, 2006, 05:47:46 pm »
Could be a bug. I job for SWINDUS  :-)
I don't use joysticks but that is the second post I have seen about joysticks problems with RC7
swindus
  • Last login:July 28, 2021, 05:52:50 am
    • MaLa - M.A.M.E. Launcher
« Reply #2 on: July 16, 2006, 05:30:12 am »
Found the bug. The joystick is always disabled when using a joystick with 2 axis only. There will be an update soon on the MaLa webpage.
Dreamwriter
  • Last login:August 28, 2010, 04:33:09 pm
  • Sleep is for the weak!
    • Games of Yore
« Reply #3 on: July 16, 2006, 12:33:10 pm »
Woot!  Bugfixes are always good, and that one's nasty for homebrew arcade machines, as I'd say most people using joysticks have 2-axis arcade ones :)
Although that is an interesting point, I have two joysticks per player - one analogue Ultra 360 hooked up as joystick, one 8-way X-Arcade hooked up to keyboard, it shouldn't be too hard to get the 8-way setup as two more axis of the first joystick.
tk_42_1
« Reply #4 on: July 17, 2006, 11:06:44 am »
Thanks swindus.  Looking foward to the update.
