Author Topic: CP layout suggestions  (Read 1611 times)
mrbasdf
  • Last login:January 16, 2004, 12:26:50 am
  • You are warm hungry!
« on: March 11, 2003, 12:07:39 am »
http://image1ex.villagephotos.com/pubimage.asp?id_=1806367
This is the button arrangement I'm going to use for my next arcade stick, but I want to add art to it. I'd like to do something KOF/Street Fighter themed. Only, the buttons get in the way. Any suggestions on what I should do? I may add some space to the bottom of the panel, though.
You must have confused me with a clown who gives a damn.
theblt
  • Last login:November 17, 2003, 04:53:32 pm
  • What's up?
Re:CP layout suggestions
« Reply #1 on: March 11, 2003, 09:03:48 am »
I have a suggestion.  Take out some of those buttons.  Maybe I'm wrong, but why do you need 8 buttons for an arcade machine for one player?? :o
phantompower
  • Last login:June 14, 2024, 01:20:45 pm
  • The Game is NOT Over!!
    • MameStation
« Reply #2 on: March 11, 2003, 09:26:01 am »
After having made a few panels with several different layouts, my only comment about that layout is not the number of buttons, but the placement of buttons 7 and 8 closest to the joystick and offset a little bit.
I would only guess that those buttons might get in the way when playing 4 or 6-button games (fighters) and having to find a place to rest your thumb.
For console games, you really need all of the buttons...at least 10 (unless you go 12 to account for L3 and R3 in PSX games).  I used to think the world revolved around Capcom and I only needed the 6 buttons, plus the START...then Sammy came into my life.  To play Guilty Gear XX properly, you need all four shoulder buttons.  Two for the HP and HK, and the other two for selecting the EX and alternate costumes.
Hope this helps.
Bottom line:  Stick with the number of buttons and find a different location for the two closest to the joystick and offset.  That is your thumb's resting place.
Chuck
