Author Topic: mini-itx?  (Read 2628 times)
JoeJoe97
  • Last login:September 19, 2007, 06:52:12 am
mini-itx?
« on: July 08, 2006, 11:43:45 am »
Has anyone used a Mini-itx for an audio jukebox?  I know they have onboard audio, but also they have PCI slots or USB.  Is the on board audio good enough?  Or would I need some better sound then that?  If I do bump to something better, what is a good choice?
As for my plans, I roughly picture building something like a small touch screen which would lay on top of a rack stereo system.  So the audio would only get thrown to an outside amp.  I don't know if technically you would still call it a jukebox, but you get the idea.
electricd
  • Last login:February 14, 2025, 07:59:10 pm
  • I'm not a llama!
Re: mini-itx?
« Reply #1 on: July 08, 2006, 12:20:10 pm »
Onboard audio on mini-itx would be fine...its the same audio as any other ATX board.  Hey we are only talking about Mp3s right..they are already degraded from compression anyway.
More_Beer
  • Last login:December 04, 2013, 04:46:25 pm
Re: mini-itx?
« Reply #2 on: July 08, 2006, 06:09:23 pm »
I'd give the onboard audio a miss and go with a PCI Sound Blaster Audigy...there a few different models, just get the cheapest because you only need 2.1 sound I presume. There roughly $50 (Aus).
mflint
  • Last login:March 01, 2014, 08:47:03 am
  • Shocking
Re: mini-itx?
« Reply #3 on: July 09, 2006, 12:18:54 pm »
Mini Itx- they work great, Sound is good, Just don't forget to order the power supply at the same time. Best of luck with your project.
