Author Topic: ZSNES Pal games on NTSC arcade monitor.. Please help!  (Read 1346 times)
AMDman13
  • Last login:April 08, 2023, 09:21:58 pm
  • This Cab is going to be the end of me!!
« on: July 08, 2006, 11:17:14 am »
Sorry, but I am a noob and don't want to fry my betson multisync. Is it safe to play pal games using zsnes?
My old user name was marlborroman13, but I kicked the habit many years ago!
AMDman13
Re: ZSNES Pal games on NTSC arcade monitor.. Please help!
« Reply #1 on: July 09, 2006, 08:27:54 pm »
Anyone have any ideas? I would assume that ZSNES can convert the video for me, but heck if I can't find the setting or anything on the internet.
Silver
  • Last login:December 27, 2025, 08:11:46 am
  • Cunning like the Fox.
    • Mods'n'Mods
« Reply #2 on: July 10, 2006, 05:59:02 pm »
Hi,
Assuming you are running your betson from the VGA port on your PC, then the PAL/NTSC is irrelevant.
Graphics cards are not physically capable of outputting PAL or NTSC TV signals via the VGA connector - only via the composite TV-out connector (if they have one).
Running Zsnes fullscreen (as I assume you are) - Zsnes simply uses/chooses a display mode that you set (probably in its menus) or autochooses one available in windows. (ie one compatible with your monitor).
So basically, you are safe - Zsnes is just an app and you can run PAL/NTSC games no problem - it does not generate PAL/NTSC output.
AMDman13
« Reply #3 on: July 10, 2006, 11:55:31 pm »
Sweet thanks  Silver!
Yes my monitor is being powered by a VGA card with all not safe res modes removed from windows and Znes is set to run at 640x480 FS..
This is a relief!
