Author Topic: nba maximum hantime monitor problems  (Read 3026 times)
tony1025
  • Last login:July 22, 2006, 06:51:53 am
« on: July 04, 2006, 05:23:43 pm »
does anyone know what would cause my wells gardner 25'' monitor to be fine and then go to a wide screen. Now it looks like it is a wide screen and it will not ajust. any help would be appreciated Tony
Kevin Mullins
    • Me on Myspace
Re: nba maximum hantime monitor problems
« Reply #1 on: July 05, 2006, 12:11:12 am »
Need to find out what model WG it is first.
K7000...... U5000..... ??
tony1025
« Reply #2 on: July 07, 2006, 07:09:04 pm »
25k7197 so I believe k7000
SirPeale
  • Green Mountain Man
« Reply #3 on: July 07, 2006, 07:50:47 pm »
Do the obvious thing, check for cracked solder joints.  Might need caps too.
Kevin Mullins
    • Me on Myspace
« Reply #4 on: July 07, 2006, 08:44:41 pm »
Yup.... and download and save the manuals to have handy.
http://arcarc.xmission.com/PDF%20Monitors/Wells%20Gardner%20K7000%20Manual.pdf
Specific Schematic
http://arcarc.xmission.com/PDF%20Monitors/Wells%20Gardner%2025K7191.pdf
Does the horizontal pot effect the picture at all when you try to adjust it?
(the pot itself could be bad or broken)
« Last Edit: July 07, 2006, 08:46:52 pm by Kevin Mullins »
tony1025
« Reply #5 on: July 08, 2006, 07:46:08 am »
well I put a cap kit in and seem on the underside of the board that there is many wires jumped around to make contact. should I just buy a new chassis or try to finish repair?
SirPeale
« Reply #6 on: July 08, 2006, 05:28:07 pm »
Those jumped wires are factory done.  Perfectly normal.  Finish repair.
tony1025
« Reply #7 on: July 09, 2006, 08:01:17 am »
well put it back together and the same thing, took the chassis out of my blitz and same thing could it be a tube?
SirPeale
« Reply #8 on: July 09, 2006, 08:00:11 pm »
Can you post a picture?
tony1025
« Reply #9 on: July 10, 2006, 03:22:38 pm »
replaced whole monitor and found out tube was bad but thanks for all your help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
grantspain
« Reply #10 on: July 10, 2006, 03:40:24 pm »
hmmm,first time i have ever heard of a tube causing a width problem
Kevin Mullins
    • Me on Myspace
« Reply #11 on: July 10, 2006, 05:19:10 pm »
Yeah, I'm sure it was still something on the chassis.
Hope he didn't just ditch it.....
