Author Topic: Which one of these CPU/MB Combos will make a better MAME machine?  (Read 1238 times)
G@M3FR3@K
  • Last login:December 31, 2015, 12:20:28 am
I want to build a PC (strictly for MAME use) and will probably get one of these combos as the foundation for it:
A) Intel Celeron D Processor 326 (Box Set) & ECS P4M800PRO-M Motherboard  - OR -
B) AMD Sempron Processor 3100+ ECS NFORCE3-A Motherboard
I'm not to familiar with Intel CPU's since I haven't used them in several years.  How does this Celeron compare to this (paticular) Sempron?  Is the Sempron faster?  If so, is it worth the extra $10 + HSF? Which one of these combos would you choose?
Fastest games I want to play will be the Street Fighter (MvsC, SNK vs Capcom, X-Men COTA) type fighters.  Will either of these be sufficient enough?  CHD games are not a necessity at all!
Some questions I have:
1) How much ram would be sufficient 128/256/512 mb?
2) What is the minumum PSU (watts) I should use on these systems?
3) I have a Geforce 2 MX400 32mb AGP card.  Would this suffice?
4) Which (older) build of MAME would be the best for these games?
5) What OS would be the best for this system: Windows 98/2000/XP?
Any advice/opinions will be greatly appreciated!  TIA!!
G@M3FR3@K
Re: Which one of these CPU/MB Combos will make a better MAME machine?
« Reply #1 on: June 29, 2006, 02:49:08 am »
Here is a mini-review for the ECS NFORCE3-A Motherboard:
http://forums.anandtech.com/messageview.aspx?catid=29&threadid=1737408&enterthread=y
These are Fry's Electronics sale items.  Besides having some of the worst customer service in the world I rather buy from them to avoid costly shipping fees. I'm trying to build this as cheap as possible.  :P
Here is Neweggs pricing for same combos:
        Price        Shipping
A) Intel Celeron D Processor 326 (Box Set) - $46.99       +($5.46)
    ECS P4M800PRO-M Motherboard             - $45.99       +($6.67)
        $92.88   +   $12.13   = $105.10 (Subtotal)
        Price         Shipping
B) AMD Sempron Processor 3100+               - $77.00       +($5.46)
    ECS NFORCE3-A Motherboard                  - $43.99       +($5.46)
        $120.99   +   $10.92   = $131.91 (Subtotal)
Silhouette
  • Last login:November 28, 2021, 07:37:39 pm
  • SONIC BOOM!!!
« Reply #2 on: June 29, 2006, 03:16:09 am »
I'd go with the Sempron, 512mb(1GB would be better and RAM is dirt cheap) DDR memory, and a 250w PSU. Also, the video card doesn't matter, because MAME doesn't use the video card at all, unless you use it for TV-Out, then it's fine.
Also, i'd go with the latest version of MAME, because that Sempron 3100+ is equivalent to a 3.1GHz Pentium 4. And for the OS, i'd probably dual-boot with Win98 and WinXP. 98 for running MAME and XP for system maintenance.
MPS
  • Last login:September 12, 2011, 10:24:10 pm
    • Back In Time
« Reply #3 on: July 04, 2006, 04:13:27 pm »
To me, this is a no-brainer.  Go with the AMD processor and ECS board.
I have two Midway cabaret cabinets running MAME -- one Rally-X cabinet with a horizontal monitor and one Pac-Man cabinet with a vertical monitor.  I purchased the AMD/ECS combination you list above to power both systems.  I am VERY pleased with the performance.
I had been powering these units off of some old P4 systems (1.4 Ghz and 1.6 Ghz) that were doing an OK job, but that processor/board combo price was just too good to pass up.  I have been a huge fan of the AMD-based systems and despite my concerns about using a non-ASUS board, everything worked out just fine.
The vertical unit has 512MB and an ArcadeVGA card running through a 13" arcade monitor.   Most of what I am running on that system are older games like Donkey Kong, Pac-Man, etc.  However, newer "shooter" games like Raiden and 19XX run at full speed with no issues.
The horizontal system is a slightly different story.  I am also using 512MB in this unit, but I elected to use a 15" PC monitor along with a GeForce 4 4600 card.  The reason was that I also wanted to throw in some arcade-style PC games like NFL Blitz, Pac-Man Adventures in Time, Frogger 2, and Dragon's Lair.  Just like the other systems, no problems with running any of these titles at full speed.
I'm not into fighters, but I would imagine that they would run OK considering how efficiently everything else seems to be.  I could try running some of those games on my rig and let you know how the performance is.  I probably won't get to it before this weekend.
Remember, the CPU in this bundle is OEM, so there is no heatsink or fan.  I found some nice Gigabyte heatsinks at my local Microcenter for $12 each.
MPS
    • Back In Time
« Reply #4 on: July 04, 2006, 04:23:38 pm »
Oops, I forgot to answer some of your questions.
1.  I have 512mb in both of my cabinets.
2.  I am using Seasonic 450 watt power supplies in both of my cabinets.  They are probably overkill, but they are VERY quiet.  The last thing I want from my cabinets are the sounds of PC's running inside.
3.  Video should be the last thing to concern yourself with in a MAME cabinet UNLESS you are going to do the things I am doing -- i.e. use a real arcade monitor or run 3D-enabled PC games.  Your card should be OK.
4.  I think the AMD/ECS combo will give you enough power to negate the need to run an older build of MAME.  I am using 0.96.
5.  I am using Windows 2000 in both cabs -- less unneeded crap to disable.
