Author Topic: Vertical Rolling on LCD.  (Read 2731 times)
Witchboard
« on: June 24, 2006, 12:36:29 am »
I've searched for vertical rolling and found several threads, but I figured I would post a new one considering I'm kind of going backwards compared to most.  I got a PSOne LCD that I'm using in a JAMMA test rig and I'm getting some vertical scrolling on it.  I've checked the voltage on the sync line and it's a little over 5 volts DC.  Do you think putting a trim-pot in the sync line might help resolve this?  is a link to an example video I shot.
grantspain
Re: Vertical Rolling on LCD.
« Reply #1 on: June 24, 2006, 03:56:57 am »
don't look like a sinc issue to me,its just vertical hold,but you could try link hor/vert sinc if you have those on the lcd input
Silver
  • Last login:December 27, 2025, 08:11:46 am
  • Cunning like the Fox.
    • Mods'n'Mods
« Reply #2 on: June 24, 2006, 09:28:57 am »
Have you hooked up any other shources to the LCD - do they work?
I don't think you should be reading 5V DC on the sync line. The sync lines are pulses of voltage (could be -ve or +ve) that you can't really read without a tv signals reader or a waveform monitor. So taking a DC voltage is just going to give you a DC Bias on that line - which is not the sync voltage.
Witchboard
« Reply #3 on: June 24, 2006, 10:20:12 am »
According to the instructions I used to hook up the LCD it has composite sync input.  It was meant to hook up from VGA, but I just used the RGB, Ground and Sync wires.  I didn't use the PCB, but cut the wires and solered them directly to a 10 pin connector.  I didn't see any other components on the board.
No, I haven't tried any other sources, and it may no longer be an option since I've cut the wires, but I'll see what I can do.
You're talking above my head.  I just checked the voltage of the sync line coming from my JAMMA harness.  I'll take your word on everything else.
grantspain
« Reply #4 on: June 24, 2006, 01:00:56 pm »
its possible your sinc input may need a different common,but if you have followed the instructions to the letter then it should be o.k,only other thing i can think of is did you use shielded cable.surely that screen must have some kind of vert hold pot though
Kevin Mullins
    • Me on Myspace
« Reply #5 on: June 24, 2006, 01:27:52 pm »
This is the most common setup I have found for this .....
http://www.arcadecollecting.com/info/sonylcd.jpg
I haven't done one myself yet, so I'm not exactly sure what all is on that little pcb.
But it looks pretty straight forward.
Have you tried any other jamma game pcb's with the setup you have now?
Witchboard
« Reply #6 on: June 24, 2006, 03:55:46 pm »
I haven't found a vert hold pot anywhere on the board.  I'll unmount it and double check though.  I'm not sure what you mean by shielded cable.  I'm using my Neo-Geo for the test signal straight from the JAMMA harness and I haven't added any extra cable to the PSOne harness so it's all the same cable as before.  :-\
I have pretty much that same thing, but I looked at the board in the picture and didn't see any components on the board, so I just traced out the wires with an ohm-meter and cut them then directly soldered them to a connector for the monitor.  I haven't tried another game PCB to test.  I'll try that next.  Thanks.
Witchboard
« Reply #7 on: June 25, 2006, 07:25:52 pm »
I used a different board with a different JAMMA harness and everything seems well.  I guess my Neo-Geo has an oddball signal or something.
Kevin Mullins
    • Me on Myspace
« Reply #8 on: June 25, 2006, 09:02:46 pm »
I vaguely remember something about the Neo-Geo boards doing that to certain monitors and such. But can't think of the details for the life of me. Weaker signal than usual or something maybe.
Glad it's up and running good now though.
Witchboard
« Reply #9 on: June 25, 2006, 09:21:47 pm »
Me too.  Thanks for the help everybody.
