Author Topic: The Great TV FAQ Thread  (Read 2577 times)
camsauce
  • Last login:May 08, 2015, 06:39:26 pm
    • Spencer*Arcade
« on: June 22, 2006, 01:03:17 am »
Hi All,
I'm hoping we can use this thread to collect data on using TV's as monitors in MAME cabinets.  I think it would be beneficial if those of you using a TV in your cab post the following:
- Make and Model of TV
- Size
- Front or Back Video Inputs (S-Video, Component etc.)
- Whether or not your TV remembers the video input selction if unplugged/powered off
- Speakers on the side or bottom
- General pros or cons
- Video card used and type of output
-CamSauce
ArtMAME
  • Last login:August 05, 2020, 12:59:17 pm
  • Hey where the ARCADE MACHINES at???
    • Art's Arcade Lab
Re: The Great TV FAQ Thread
« Reply #1 on: June 22, 2006, 10:15:53 am »
JVC AV-27530
- Size
27"
Component, S-Video, Composite, RF in the rear
Composite in front (I think)
I am using Component inputs
Yes, TV remembers settings and input selection
bottom
Pros
Picture looks awesome when using component video inputs, especially for old-school games (Defender, MsPacman, Robotron, DonkeyKong, etc..)  Even color vector games look good like Tempest, Black Widow, etc...  I have a 29" presentation monitor(1024x768) that I could put in my cab, but I am really happy with the way the picture looks.
Cheaper than new arcade monitor of same size.  (I paid less than $200 new from hhgregg)
TV can be squeezed into a big Jamma cabinet with out de-casing (my cabinet originally housed a 25" WG monitor).  Some relief cuts are required on the rear plastic casing of the TV to achieve this though.
See my project thread: http://forum.arcadecontrols.com/index.php?topic=54556.msg534947#msg534947
Cons
Can only use 640x480 in MAME when using Component inputs.  Not a problem with 99.9% of games.  Asteroids looks horrible though.
Overscans a little but can be adjusted by entering the service menu and shrinking the height a little bit.
Hard to find these new in the store anymore  :cry:
UPDATE!!! Browsing through the Brandsmart weekly ads and it looks like they have these for $168.88!!! http://www.brandsmartusa.com/aga/p4.htm Get 'em while they last!!!  :cheers:
Radeon 9550 (MSI) with DVI to Component adapter using 480i dip switch setting
(This adapter only works with Radeon 9500 family or better, and Nvidia 6600 or better)
« Last Edit: July 12, 2006, 11:32:29 am by ArtMAME »
"Klaatu. .. Verada. ...... Necktie...Nectar...Nickel..."
camsauce
    • Spencer*Arcade
« Reply #2 on: July 12, 2006, 12:51:04 am »
Samsung TX-R2435
- Size
24"
Rear and Side Composite
Rear S-Video
Rear Component
Yes
Side
Pros
Picture quality is quite amazing even with only S-Video, I placed it side-by-side with a 17" Monitor and calibrated accordingly until it looked almost identical in quality.  I anticipate the quality to improve somewhat with a component connection
Flat Screen. I know that this is not the 'authentic' approach for an arcade cabinet but I feel the picture quality improvement is worth it
Shallow depth for cabinet mounting
Quick screen refresh (as in when I turn it on it doesn't take but 2-3 seconds for the screen to display in 99% brightness)
Cons
TV is pretty heavy ~70lbs
TV does not auto power on after being unplugged/power failure
Somewhat spendy +/- $250
Old 16MB PCI ATi Rage 128 (All in Wonder) using S-Video
I consider a 24" a perfect size when viewed up close especially with a cabinet.  I own a 27" TV and it gave me a headache standing ~20" from the screen
ChicagoDave
  • Last login:May 18, 2023, 11:08:23 am
    • Dave's Website
« Reply #3 on: July 13, 2006, 12:43:26 pm »
Mitsubishi CS-27MX1
- Size
27"
Rear S-Video and RCA
Yes, it remembers
Bottom
Pros
S-Video, Resume after power loss, pretty good picture.  Only $90 used on ebay.
Cons
Slight doming problem on bright images
ATI Radeon 9500 Pro using the S-Video TV Out
Homer Simpson:
"Here's to alcohol, the cause of, and solution to, all life's problems."
mark6437
  • Last login:March 23, 2020, 03:20:11 pm
  • THB2
« Reply #4 on: August 02, 2006, 12:54:21 pm »
Ok thx I will look into all these options.
Mark
