Author Topic: MAMEWah Exiting  (Read 1662 times)
toasty
  • Last login:October 10, 2019, 11:48:47 am
  • Purveyor of Fine Latex Products
MAMEWah Exiting
« on: June 19, 2006, 10:32:13 am »
For some reason, when I exit from a MAME (v.105) game in MAMEWah (v.1.62b10), MAMEWah exits me back to windows.  It doesn't do it immediately, and if I can load another game before it does so, I'm fine, but I only have about a 5 second window of time before it will flip back to windows.
As an aside, it only does this with MAME -- the other emulators work just fine.
Any thoughts?  Here's the most recent log:
6/19/2006 9:29:25 AM MAMEWAH v1.62 launched
6/19/2006 9:29:25 AM Cursor scheme: Windows default, Arrow: (None), Wait: (None), AppStarting: (None)
6/19/2006 9:29:25 AM Desktop colour: 9981440
6/19/2006 9:29:25 AM Wallpaper filename: C:\Documents and Settings\Jamie\Local Settings\Application Data\Microsoft\Wallpaper1.bmp
6/19/2006 9:29:25 AM Display mode: 1152x864 @ 60Hz, 32 bit colour
6/19/2006 9:29:25 AM Decimal symbol: '.'
6/19/2006 9:29:25 AM Games list read: fceu-0.lst
6/19/2006 9:29:28 AM Mode 640 x 480 @ 60Hz, 16bit colour selected after 2 attempt(s) at 1/2 second intervals.
6/19/2006 9:29:29 AM Layout selected: F:\mamewah_v162b10\config\layout.lay
6/19/2006 9:29:29 AM No. joystick devices attached: 0
6/19/2006 9:29:29 AM Ctrlr file selected: F:\mamewah_v162b10\config\mamewah.cfg
6/19/2006 9:29:30 AM Keyboard enabled
6/19/2006 9:29:37 AM Mode 800 x 600 @ 60Hz, 32bit colour selected after 2 attempt(s) at 1/2 second intervals.
6/19/2006 9:29:38 AM Layout selected: F:\mamewah_v162b10\config\mame\jcrouse\layout.lay
6/19/2006 9:29:38 AM Games list read: mame-0.lst
6/19/2006 9:30:01 AM f:\winipac\winipac.exe does not exist in LaunchApplication.
6/19/2006 9:30:02 AM Mode 800 x 600 @ 60Hz, 32bit colour selected after 2 attempt(s) at 1/2 second intervals.
6/19/2006 9:30:02 AM Current drive/directory selected: f:\mame
6/19/2006 9:30:02 AM Commandline run: C:\WINDOWS\system32\cmd.exe /c f:\mame\mame.exe klax -verifyroms > F:\MAMEWA~1\files\verify {flags=81}
6/19/2006 9:30:02 AM Application quit: C:\WINDOWS\system32\cmd.exe /c f:\mame\mame.exe klax -verifyroms > F:\MAMEWA~1\files\verify
6/19/2006 9:30:02 AM Commandline run: f:\mame\mame.exe "f:\mame\roms\klax.zip" {flags=204}
6/19/2006 9:31:22 AM Application quit: f:\mame\mame.exe "f:\mame\roms\klax.zip"
6/19/2006 9:31:23 AM Mode 800 x 600 @ 60Hz, 32bit colour selected after 2 attempt(s) at 1/2 second intervals.
6/19/2006 9:31:23 AM Error: 62 Input past end of file in UpdateFAVList
6/19/2006 9:31:23 AM f:\winipac\winipac.exe does not exist in LaunchApplication.
6/19/2006 9:31:24 AM Mode 800 x 600 @ 60Hz, 32bit colour selected after 2 attempt(s) at 1/2 second intervals.
6/19/2006 9:31:29 AM Error: 55 File already open in INI_SaveConfig
6/19/2006 9:31:29 AM Error: 55 File already open in EMUINI_SaveConfig
6/19/2006 9:31:29 AM Error: 55 File already open in LISTINI_SaveConfig
6/19/2006 9:31:30 AM Mode 1152 x 864 @ 60Hz, 32bit colour selected after 1 attempt(s) at 1/2 second intervals.
6/19/2006 9:31:31 AM MAMEWAH quit
I note this makes reference to the resolution right before it quits.  I've been having some issues with the resolution jumping around as well.  Could that be related?
TIA
Re: MAMEWah Exiting
« Reply #1 on: June 20, 2006, 09:14:28 am »
This is causing the problem...try deleting your \mamewah\files\*.fav files.
This shouldn't really matter, but you might want to address this anyway.
toasty
Re: MAMEWah Exiting
« Reply #2 on: June 20, 2006, 11:41:25 am »
thanks bro -- I'll give it a try...
