Author Topic: z26, using Midway 49 ways, and video settings.  (Read 1343 times)
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« on: June 19, 2006, 03:55:07 am »
I read the manual, and I have a few issues with the z26.cli file.  I did get it to recognize the controller.  In Yars Revenge, the spinners work for X and Y axis.  When playing Super Breakout, the spinners don't work, and player two has to use the Y axis on player 1's 49 way to move left and right.  I can't figure out what to input to get z26 to find the spinners or the second player's joystick.
Second, I am using component video, and I can't get it to go full screen or refresh at 30hz.  Any ideas fellas?  Here is my z26.cli file and what each command does:
-v0                    this is the video mode 400x300 (default)
-r30                  run at N frames per second
-)CCJS              Left Port joystick
-(CCJS              Right port joystick
-m101               Mouse to represent both x and y paddles and what port (-m1xy)
-n                     show scanline count and fps on game display(not working)
The entire emulator and support files can be downloaded here:
http://www.emuchrist.org/cpviewer/downloads/z26ini.zip
The instructions I'm using are in the .pdf file in the docs folder.
« Last Edit: June 19, 2006, 04:10:10 am by mccoy178 »
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
Re: z26, using Midway 49 ways, and video settings.
« Reply #1 on: June 19, 2006, 04:01:16 am »
Okay, with the above settings, both joysticks work.  In Frogger, both joysticks work for the according player.  I just don't understand the video issues or the spinner problems with Breakout, Super Breakout, and Warlords(These are the three paddle games I've tried).
« Last Edit: June 19, 2006, 04:09:18 am by mccoy178 »
DeafBug
  • Last login:April 14, 2008, 06:00:35 pm
  • HUH?
« Reply #2 on: June 23, 2006, 03:31:06 pm »
Thank you for providing the link.  Just one question.  Is the software version in the link you provided have the ability to use IPAC on MAME?  I want to do away with the atari console and use the Atari ROMs on the PC with IPAC with the z26 emulator.
I did a search and many if not all the links provided in the post are outdated or dead links. I was surprised to see yours.  I will try to get some work going next week or so.
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #3 on: June 25, 2006, 04:36:20 pm »
I do believe it can.
