Author Topic: Multi Williams Jamma board wiring?  (Read 1935 times)
markymarky99
  • Last login:August 20, 2017, 01:53:05 pm
« on: June 19, 2006, 01:34:41 am »
HI, anyone know how to wire the Multi Williams Jamma boards that are out there?  There are so many buttons for Stargate / Defender, how do you know which wire
goes to what button?  Thanks for your time
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Re: Multi Williams Jamma board wiring?
« Reply #1 on: June 19, 2006, 12:42:45 pm »
I am going to presume that this is one of the multi-in-one boards, as opposed to one of Clay's MW kits (pretty obvious since you said JAMMA board, but to be clear..).
Further, I'll assume that it is one of the ArcadeShop boards, since I know where to find the pinout for that:
http://www.arcadeshop.com/multi-pcb/multi-pcb.htm
HTH, Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
