Author Topic: angle joystick or not?  (Read 3460 times)
jim_daniels
  • Last login:June 09, 2003, 12:21:22 am
« on: March 07, 2003, 02:34:42 pm »
I'm building a large 2 player cp and can't decide if the joysticks should angle in just a little or be straight on.  The reason I want to angle them is that there is a 4-way and trackball in the middle, so I angled the sides to make it more comfortable.  But is angling the joystick going to cause a problem? Are people going to hit diagnals trying to go up, for ex?  I'm not talking anything extreme here, just a slight angle on the stick and buttons
CitznFish
  • Last login:November 13, 2024, 01:18:45 am
  • www.subvertcity.com - Prof. Strength Slackwear
Re:angle joystick or not?
« Reply #1 on: March 07, 2003, 02:44:31 pm »
the only designs I have seen with angles joysticks are for the 3rd and 4th players. I wouldn't angle them. I haven't seen any of the control panels on the examples pages with angled joysticks for player 1 or player 2. you should stick with what works, or you could mock one up and see how it feels.
just my $.02
jim_daniels
« Reply #2 on: March 07, 2003, 02:59:24 pm »
Check this one out, this looks a lot like my cp. (minus all the cool artwork, though :-[)
http://www.leafstation.com/ms2home.html
Do you think that angle would be confusing?
BobA
  • What Me Worry?
« Reply #3 on: March 07, 2003, 03:09:14 pm »
If your cp is wide enough I do not think an angle would be required.   To get a feel for doing things on a slight angle try holding your mouse about 25 degrees off how you usually hold it.  Now try to use it.   You can adapt to the new angle quite quickly but the moves are not as  quick or as accurate.  Same thing happens if you are trying to compensate for a joystick being at an angle.   It will work but in my opinion it will never feel quite right.
Just my 2 cents.
BobA
Dartful Dodger
  • Newer isn't always better.
« Reply #4 on: March 07, 2003, 03:26:15 pm »
I think you should keep the joystick, and all the buttons level to the bottom of the control panel, if the control panel is curved or shaped in a way so that the player needs to stand at an angle to play, then an angled joystick is best.
Rocky
« Reply #5 on: March 07, 2003, 10:16:40 pm »
I like the joysticks on my panel straight. It feels fine and it also helps for 2 joystick games like:
- Crazy Climber
- Robotron
- Cloak & Dagger
It's all about finding what works for what you want to play.
Rocky
BombProofPlane
  • Last login:February 11, 2009, 04:14:14 pm
« Reply #6 on: March 08, 2003, 01:20:07 am »
ultimarc makes the e-sticks that fit in joystick holes and you can rotate them freely check em out
http://www.ultimarc.com/controls.html
