Author Topic: Problems setting up MaLa with Daphne  (Read 11917 times)
8way
  • Last login:February 03, 2017, 05:52:21 am
  • This is my BOOM stick!
« on: June 16, 2006, 04:11:11 am »
Can someone please show me an example of their daphne.bat and game.bat files? I just can
swindus
  • Last login:July 28, 2021, 05:52:50 am
    • MaLa - M.A.M.E. Launcher
8way
Re: Problems setting up MaLa with Daphne
« Reply #2 on: June 16, 2006, 06:51:19 am »
Here is my daphne.bat and Cobra_command.bat. Still not working...
8way
« Reply #3 on: June 17, 2006, 07:36:41 am »
I still need help on this... Please anybody?
swindus
« Reply #4 on: June 18, 2006, 01:41:05 pm »
What are your emulator (executable and command line) settings in MaLa to launch Daphne (the batch files)?
8way
« Reply #5 on: June 18, 2006, 05:15:10 pm »
All I have is emulator executable pointing to the daphne.bat and I picked Daphne from the drop down preset list. Is their something else im suppose to do?
loadman
  • Moderator
    • MaLa
« Reply #6 on: June 18, 2006, 06:56:41 pm »
Post a screenshot of your 'basics' and 'execution' tab so we can see what you have set please..
8way
« Reply #7 on: June 19, 2006, 07:51:01 am »
my setting.....
swindus
« Reply #8 on: June 19, 2006, 08:24:45 am »
Try to use the following command line: %rom%
In the daphne.bat file the game name/rom name is mapped to a bat file:
IF %1==Cobra_Command %BATCHPATH%\Cobra_Command.bat %DAPHNE%
So there is no need to send the path or the extension to the daphne.bat. I will also change the command line for daphne in the emulator preset file.
« Last Edit: June 19, 2006, 08:32:39 am by swindus »
unclet
« Reply #9 on: June 19, 2006, 03:03:59 pm »
I just got back from being gone all weekend ..... I will take a look at how I have configured my Daphne files when I get home tonight .....  I know I do not use a Daphne loader .....
8way
« Reply #10 on: June 19, 2006, 06:43:42 pm »
I really appreciate the help swindus :notworthy:. Changing the command line to %rom% solved  the problem. Now it works perfectly. Thanks again for all the help. Now it
unclet
« Reply #11 on: June 19, 2006, 08:51:38 pm »
Ok, glad to hear it works.......  good job
swindus
« Reply #12 on: June 20, 2006, 03:23:18 am »
I would prefer Howard's wrapper and his Zinc Config Utility to setup Zinc. Works perfect with MaLa!
http://forum.arcadecontrols.com/index.php?topic=52607.0
