Author Topic: Forcing 640*480 via Mamewah resolution tool?  (Read 1476 times)
Gaston77
  • Last login:February 21, 2011, 06:53:44 am
  • MDF nearly killed me!
« on: June 14, 2006, 04:55:58 am »
How can I quickly force 640*480 with hwstretch 1 on every game using the resolution tool? I don't want to go through every resolution and change every single game.
Reason for this is that some vertical shooters look too small on my big D9200 screen. I don't care that it won't be 100% true to the original ratios...
this is my........BOOMstick!
8way
  • Last login:February 03, 2017, 05:52:21 am
  • This is my BOOM stick!
Re: Forcing 640*480 via Mamewah resolution tool?
« Reply #1 on: June 14, 2006, 07:21:38 am »
Just change the resolution from
« Reply #2 on: June 14, 2006, 07:49:29 am »
Gaston77
« Reply #3 on: June 14, 2006, 08:03:28 am »
Tis a shame not to put that screen to it's potential tho, many games will look poor with those settings :(
I agree Minwah. I did buy the D9200 with that in mind. What would you suggest in that case though? It would more or less mean that I would need to go through every resolution in the restool and change the settings per game. I have already made sure that all games should use their native settings. If no ideal setting is found, 640*480 hwstretch 1 will be used.
What would you suggest?
« Reply #4 on: June 14, 2006, 08:17:22 am »
You may have already done it then...the Res Tool if properly configured should pick the best modes for you.
Read my included readme file and it gives you a quick how-to - that should get you on the right tracks (if you're not already!) :)
