Author Topic: Prepare to Qualify - Driving Cabinet - Complete!  (Read 37135 times)
Re: Prepare to Qualify - Driving Cabinet - "Assembled" some controls
« Reply #40 on: June 14, 2006, 09:35:31 am »
I've got a gutted Taiko driving cab in my garage, awaiting my attention (one project at a time).  It does not have a steering wheel.  Did your unit include a wheel?  Any recommendations on buying/building one?
mine came with the atari wheel... Are you wanting to do mame or x-box/ps2 games with it? I'd say the only concern would be how you plan on hooking it up to your computer. The mouse hack I did works, but I wonder if there is another way. If your wanting to go x-box, you'll have some easy choices for steering wheels and arguable much better and more games to play.
What games are you wanting to play? This guy will play about 20 racing games from the arcade and a couple other games (puzz loop, cameltry, etc.). My monitor is setup horizontal as most racing games are horizontal.
Overall, I like the atari steering wheel. It's what I am used to seeing in the arcades.
theCoder
« Reply #41 on: June 14, 2006, 10:25:27 am »
I'd love to use an x-box, but I don't think my son would part with the box.  It's mod'ed and loaded up.  I love the driving games you can play on an x-box.  Perhaps I could track another one down for cheap?
I was originally thinking of going with a high(er) end PC running windows driving games, such as the "Need for Speed" series.  The mame driving games just don't cut it for me.  I do however like the idea though of being able to play other mame games on it (with a joystick on the left and a series of buttons on the right.  My daughter loves Step Mania, and whatever cab it is on, it will be going non-stop during any of her parties.
I'm intrigued about going with an X-Box though.   I think I'll look into it some more.
The cab I've got has one pedal mounted at the base.  It appears to just have a switch, no pot and also no break pedal.  What kind of setup do you have for pedals?
« Reply #42 on: June 14, 2006, 11:43:50 am »
I have 2 pedals - both switches. I've confirmed they work in mame for the games I want. Not as great as pots for some games, but they'll do. If you go the xbox route - you'll get a 270 degree steering wheel, some pedals and a shifter for the xbox. Check out Markvp's work on his sit down xbox game. It's awesome.
« Reply #43 on: June 15, 2006, 12:42:55 am »
Alright! Got tired quick tonight so I'm calling it a night - here is what I've done:
reinstalled the mouse hacked steering wheel. Now that it's installed and the paper isn't rubbing on the mouse pcb, I am never going to move it... ever (I hope).
Installed the marquee. This time around I used the router to cut the plexiglass. I tried to snap it using the razor blade technique and I got a little impatient and tried to snap it too early. It was pretty late and I didn't want to setup the router and everything... turns out I should've. It's amazing what the right tools will do. It took me 20 minutes to get a new bit in the router and like 30 seconds to trim up the plexi... or lexan or whatever.
Wired up the controls. Well, I ran all the grounds. Thats the biggest BS part of this anyhow.
I drilled the holes in the CP for the player 1, credit, and quit button (they go on the front of the CP). I used an electrical plate to cover the hole in the metal CP by the old shifter. I drilled a hole in the center of it for games that require both a turbo button and a fire button. I said games... but I can only think of 1. Special Crime Unit... or something like that.
thats about it! Here are some pics of the marquee and cp in it's final resting place.
About the marquee:
I printed it at Kinkos - 24 x 7.5 on backlit vinyl. Cost right over $16. It turned out pretty nice. Now, the artwork may be a bit on the generic side. I wanted to match the cabinet color wise and pull in a bit of a racing theme. Overall, I'm happy with it. It's not a work of art, but I can say I did it.
Whats left:
Install ipac
install t-mold
install back
install plexi
configure games
I'll be off to the races!
Crafty
  • Last login:March 19, 2009, 11:32:25 pm
« Reply #44 on: June 15, 2006, 02:23:39 am »
Looking good..
You will be qualifying in no time...
A Bad Day Playing Is Better Than a Good Day Working
Ninten-doh
  • Last login:March 31, 2017, 10:37:18 am
  • I promise sweetie, this is my last cab purchase
« Reply #45 on: June 15, 2006, 08:41:22 am »
Marquee came out great!   :applaud:
I know it's the flash, but I kinda like that first pic with the yellow sunburst thing going on.   :)
« Reply #46 on: June 16, 2006, 03:25:24 am »
Not much in the way of updates tonight...
I finish setting up the computer as far as configuring all the games to work with the steering wheel and adjusting the sensitivity. It seems fine. I'll know for sure once I get the ipac in and can use the pedals and shifter.
Re: Prepare to Qualify - Driving Cabinet - Complete!
« Reply #47 on: June 19, 2006, 08:19:25 pm »
Got the last bits and peices wrapped up today. Lucked out and Mala released a new version which allows me to use my steering wheel to navigate games.
The T-molding came in today. You can't tell by looking at it, but this cab needs about 21 feet of T-molding. I cut a bit off in 1 location and it's hardly noticeable. Next time... I measure before I order the t-molding. I just thought 20 feet would be more than enough - it's not that tall of a cabinet.
It was a fun project and didn't take long. There aren't a ton of driving games I like, but I have plenty of friends, neices and nephews who would play this. I stuck some non-traditional games on there too - Cameltry, Kick, Tempest, Arkanoid, Paperboy...
The encoder wheel + mouse pcb combination works great. The only games it's not the best with are 270 degree steering wheel games like Outrun. But for games like championship sprint, and APB it's great. The microswitch pedals are a bit of a hassle in some games, but they do the job.
Alright, without further delay, here are the last of the pictures. My next project is a xenophobe cabinet thats been converted to Combatribes and is going to be turned into a showcase cabinet.
I'm really happy the stripes turned out like they did. It was worth the hassle.
Thats a fine ass on this 30 year old arcade!
Cameronj
  • Last login:August 03, 2012, 12:59:01 pm
  • I'm a Super llama!
« Reply #48 on: June 19, 2006, 08:55:35 pm »
Looks awesome!!!!!! I am impressed. This gives me some inspiration for a similar project in the future.
Enjoy!
gamecreature
  • Last login:October 29, 2008, 08:35:37 pm
  • I'm making this up as I go along.
    • Gamecreature
« Reply #49 on: June 19, 2006, 09:36:57 pm »
Very sharp! I should have you finish the outside of my cab! :)
Make your cabinet look its best with custom art from
Gamecreature!
« Reply #50 on: June 19, 2006, 09:43:36 pm »
And you could've done my artwork! Brilliant!!
heh. Thanks! Yours is looking great - keep up the good work.
Crafty
« Reply #51 on: June 20, 2006, 02:26:24 am »
Well done
Look forward to your next project
Havok
  • Trade Count: (+17)
« Reply #52 on: June 21, 2006, 09:25:26 pm »
F'ing beautiful!
I love the FE theme, it totally fits.
« Reply #53 on: June 23, 2006, 10:21:34 am »
F'ing beautiful!
Thanks Havok.
In case you didn't know, the FE is Mala and it's the greatest thing since Mamwah. The only issue I have with mala is that it's a tad slow scrolling up and down the list with the joystick. The steering wheel cruises through the list. Other than that, it's an awesome front end.
gamecreature
    • Gamecreature
« Reply #54 on: June 23, 2006, 10:39:07 am »
F'ing beautiful!
Thanks Havok.
Did you know you could hold down the ctrl button (usually the Player 1 fire button) for a quick page-up/down through the Mala list? Goes a lot faster then. :)
Gamecreature!
« Reply #55 on: June 23, 2006, 10:46:38 am »
No I didn't. Good tip! Thanks.
miles2912
« Reply #56 on: June 23, 2006, 12:57:32 pm »
That is awesome.  Nice work on a driving cab.
D-
Havok
« Reply #57 on: June 23, 2006, 01:53:51 pm »
You realize this now forces me to start work on a driving cab. I've been toying around with the idea to build a modded Xbox, and put it in a cabinet. Now, I think I'll have to follow through. And it's all your fault!
My wife is going to be pissed at you...
 :D
« Reply #58 on: June 23, 2006, 02:07:13 pm »
 :D
Xbox is a great idea. I debated on going x-box or arcade. Personally, I don't care for driving games that much either way. heh. Obviously X-box has the better/most games. I am using mine to play arcade games because it's an arcade cabinet and it just feels right. I could change it up to xbox easy enough, but for some reason if I play x-box driving games, I'd like to play them on a couch in front of a big tv.
Tell your wife to join the pissed wifes club. BYOPW. I already got my old lady mad, whats 1 more. (old lady is a term of endearmont in Illinois...  ;D )
clanggedin
  • Last login:July 02, 2012, 11:08:55 pm
  • O'DOYLE RULES!!!
« Reply #59 on: June 23, 2006, 03:29:29 pm »
I have a Ridge Racer II upright cab that I sold the guts to a few months back just waiting to be worked on.  I am going to convert it to a dreamcast cab and run crazy taxi in it hopefully.
This thread has got the fires burning in me to work on that now.
vrf
  • Last login:October 13, 2017, 10:11:54 pm
    • Pixelbox
« Reply #60 on: June 23, 2006, 06:55:18 pm »
Great work! Feels like you finished pretty quickly, too.
Now I'm inspired to build a driving cab. (A mini one.) I like the profile on your cab.
Crafty
« Reply #61 on: June 25, 2006, 03:10:24 am »
You guys sure know how to make life difficult...
all these amazing cabinets being built...
How is a newb supposed to ever get started...
I want them all  Upright, Cocktail, Driving, Barcade oh the list goes on..
Where will I fit them???
danny_galaga
  • Last login:Yesterday at 07:16:44 pm
    • dans cocktail lounge
« Reply #62 on: June 25, 2006, 04:42:26 am »
i like it! hard to see on my housemates crappy monitor but looks nice. the steering wheel is original, right? what about the gear shift thingo?
theCoder
« Reply #63 on: June 25, 2006, 10:19:43 pm »
One cab at a time.  I'd recommend converting an existing cab.  You get a jump start on the construction.  Just do it!
Sounds like we may see a flurry of driving cab projects coming up in this forum.  Yesterday I made up my mind.  I picked up a mod'd XBox from dweebs0r, I picked up a 27" TV at a garage sale ($10 - what a steal), and I've got a large profile dead cab in my garage (free from a nice retired gentleman).  See you at the finish line.
« Reply #64 on: June 26, 2006, 08:05:00 am »
The gear shift is a happs return to center turbo button gear shift. I picked it up on ebay for $40. Although not authentic for every game, it provides an acceptable level of performance. I wasn't a big arcade racer - this was more for my neices and nephews than for me.
« Reply #65 on: June 26, 2006, 08:05:45 am »
Awesome! I look forward to seeing your project!
MameMaster!
  • Engage number one!
    • Mame Invaders!
« Reply #66 on: June 26, 2006, 12:02:44 pm »
excellent job and great looking FE.
Enjoy your new toy!  :cheers:
BlinKY1337
  • Last login:October 25, 2013, 11:06:36 am
« Reply #67 on: June 28, 2006, 12:52:57 pm »
That Mala template works perfect with this great job :) :cheers:
« Reply #68 on: June 28, 2006, 02:03:38 pm »
As for Mala - it's awesome so far. I have no complaints with it. I need to hide XP a little better, but other than that it's a great FE.
This cabinet was fun to make. I especially like the stripes. The stripes was a side effect of being cheap and not wanting to buy side art. They worked out well. I'm halfway through my showcase cabinet build and haven't had much time to play this, but I'm looking forward to gaming more after I get my last cabinet built. I did manage to play a few racing games last night and so far so good on the mouse hack.
loadman
  • Last login:January 29, 2026, 07:18:10 pm
    • MaLa
« Reply #69 on: June 28, 2006, 06:45:01 pm »
What issues to you have?
Maybe we can point you in the right direction to find a solution
« Reply #70 on: June 28, 2006, 09:04:35 pm »
I should specify. I need to actually do it - not that I don't know how to do it. Real good directions were in the Hiding XP Threadhttp://forum.arcadecontrols.com/index.php?topic=53467.0
Thanks for the help though Loadman!
