Author Topic: JPAC + Input Button 4  (Read 1101 times)
DaveJ-UK
  • Last login:January 11, 2025, 04:20:37 am
  • Dirty Dawg
    • ChronicGames.NET
« on: June 07, 2006, 11:40:11 am »
I have the first 4 buttons wired directly to the JAMMA harness and buttons 5 and 6 connected to my JPAC's P1B5 and P1B6.
However I notice that it also has a P1B4 screw connection - why does it have this if it goes directly through the JAMMA harness anyway?
It's definitely meant for button 4 because it generates the same keystroke (left shift)? Is it just there for convenience if you have a 3 button cab and dont want to wire the exrtra button to the harness?
nobbo
  • Last login:July 30, 2008, 09:38:37 pm
Re: JPAC + Input Button 4
« Reply #1 on: June 07, 2006, 07:09:58 pm »
i believe the official jamma standard was 3 buttons, although some machines extended this to 4 buttons, and of course the capcoms of the world invented jamma+ which is 6 buttons per player, so most jamma cabinets will only have 3 buttons wired, but some (like yours) use 4 buttons directly into the harness.
there is no difference whether you use the screw terminal on the j-pac or the harness though
CheffoJeffo
  • Cheffo's right! ---saint
  • Last login:July 14, 2025, 12:11:49 pm
  • Worthless button pusher!
« Reply #2 on: June 07, 2006, 07:41:15 pm »
As nobbo says, JAMMA standard is 3-buttons, although some cabinets will wire button 4 to pins c and 25.
From the JPAC FAQ:
Note that button 4 can be connected via either method as some JAMMA harnesses route this button through the connector.
Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
