Author Topic: Mala Question - How can I have left right go down game select list  (Read 8514 times)
  • Last login:Today at 04:07:39 pm
I want to use my left and right joystick movements to go up or down a letter with mala. I can't find the setting. Is there one?
loadman
  • Moderator
    • MaLa
Re: Mala Question - How can I have left right go down game select list
« Reply #1 on: June 07, 2006, 12:16:12 am »
yep... see attached
« Reply #2 on: June 07, 2006, 11:38:12 am »
ok. I clicked that and using the left or right arrows doesn't move the game list up or down by letters.
On a previous screen I notice that left and right is assigned to X up and X down. Does that have anything to do with anything?
swindus
  • Last login:July 28, 2021, 05:52:50 am
    • MaLa - M.A.M.E. Launcher
« Reply #3 on: June 07, 2006, 11:57:33 am »
These are the default controller settings:
As you can see cursor left/right is assigned to switch the game list.
Cursor up/down PLUS 'Shift' is assigned to x up and x down.
The 'Shift' key is assigned to the Ctrl key. (Player 1 Button 1 for the MAME default)
So Ctrl + cursor up/down will jump by interval or letter.
Have a look to this page if you want to reassign some keys:
http://mala.arcadezentrum.com/controllerconfig.html
german - english keys:
oben = up
unten = down
links = left
richts = right
strg = ctrl
« Last Edit: June 07, 2006, 12:11:37 pm by swindus »
loadman
  • Moderator
    • MaLa
« Reply #4 on: June 07, 2006, 06:57:06 pm »
here is what it looks like when installed on a English PC using the latest version:
« Last Edit: June 07, 2006, 07:12:07 pm by loadman »
edge
  • Last login:May 08, 2025, 09:08:47 am
  • AttractMode and GroovyArcade rock!
« Reply #5 on: June 08, 2006, 02:21:02 pm »
Swindus,
Any thoughts on allowing user to define keys to do BOTH options... Up/down interval AND Up/Down letter?
swindus
« Reply #6 on: June 08, 2006, 04:03:48 pm »
Yes, I will add the letter up/down function to the controller set, so you can use both options to scroll thru the lists.
Denverlatino
  • ---Buyer Beware - transactions with this user are in dispute--- ... Banned ...
  • Last login:May 13, 2009, 02:55:24 pm
« Reply #7 on: June 08, 2006, 09:39:58 pm »
i vote so mala has this , for a better use of mala... great fe thanks
[transactions in dispute -- see http://forum.arcadecontrols.com/index.php?topic=77030.0]
... Banned ...
