Author Topic: Selected song indicator  (Read 4429 times)
thebrokenjoystick
  • Last login:December 01, 2018, 08:23:18 pm
  • The cake is a lie
    • My Vogon Poetry
« on: June 06, 2006, 03:26:10 pm »
First off - I love Wincab - it's ALMOST perfect! I have one problem though....I am using a slightly modified version of the test skin included with Wincab (though my problem is with all the skins shipped with it) and I am using arrow key navigation to move around and an ENTER button to select. I am running at 640x480 on a 19 inch Eygo monitor. Everything looks  and works great EXCEPT the selection indicator - the little indicator you move around with arrow keys. It highlights the song with a barely visible dotted rectangle and it is SOOOO hard to see.
Is there any way to customize it? I'd like it to be a different color and maybe solid instead of dotted. I looked through the skin's files and didn't see naything that looked like a way to change this. I even changed a bunch of things I thought might be it but had no luck. Is this changeable?
Thanks,
Brian
Chris
  • Moderator
    • Chris's MAME Cabinet
Re: Selected song indicator
« Reply #1 on: June 06, 2006, 03:40:13 pm »
Right now there are no adjustments for the rectangle, but you can change the color of the text on the highlighted song.  Edit your .skn file with a text editor and add the following line to the Titlestrips section:
FontFocusColor=deepskyblue
Does that help?
--Chris
--Chris
thebrokenjoystick
  • The cake is a lie
    • My Vogon Poetry
« Reply #2 on: June 06, 2006, 03:49:29 pm »
PERFECT!!!!!! (though I changed it to red) Thanks a bunch!
Brian
