Author Topic: PC Karaoke setup...  (Read 5333 times)
Dazz
  • Last login:January 11, 2025, 07:43:39 am
  • HyperSpin Team
    • VPUniverse
PC Karaoke setup...
« on: June 05, 2006, 08:21:31 pm »
Hey Guys,
I recently ripped my whole karaoke collection to CDG/MP3 and would like to be able to run karaoke from my MAME cabinet.  I'm currenty using onboard sound and looking into getting a good sound card for karaoke use.  Need something that would allow 2+ mic inputs.  Also I'd need to get a mixer that would be good for cabinet use...  Any suggestions?
Ghoward
  • Last login:July 09, 2021, 10:45:22 pm
  • Mame rocks!!
Re: PC Karaoke setup...
« Reply #1 on: June 06, 2006, 10:41:46 am »
Hi,
I used a standard sound card but then plugged that into a Karaoke mixer, using a Radioshack cable with RCA plugs on one end. Mic inputs then go to the mixer not the pc and out to a amp. However you could route it back to the pc via line in  if you wanted to use your pc speakers.
As for putting it in your Mame cab that is a hard one my mixer for one would not fit in a mame machine. I do have it in a cab but it is bigger than a mame machine. Bottom line if you want a karaoke machine build a new cab! I did.......
You can buy sound cards with 1/4 inch jack inputs on them, I had one but ended up not using it.
Gary
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #2 on: June 07, 2006, 04:42:48 am »
Yeah when i use freebox for my karaoke i also run the mics through a seperate karaoke amp as this allows more control for volume and reverb on a per microphone basis. Ideally i want to use something simular to a shower hose to cover the mic cables to protect them simular to how light guns are hooked up to a cabinet in the arcades. You can get cheap PA or Karaoke amps off ebay.
