Author Topic: Best way to wire LED's?  (Read 1411 times)
DigDreams
  • Last login:March 07, 2007, 04:37:08 am
« on: June 03, 2006, 09:15:14 pm »
I just bought I bunch of buttons and high output LED's and was wonderig what is the best way to wire it up?  I seems kind of bulky to just solder or twist together all of the positives and grounds from a molex.  Is there something I can use that is cleaner?
I was thinking something with screw terminals like on the i-Pac, with one side being ground and one being +12v.  Is something like this available?  23 leads all twisted together seems like a mess to me. (I have 23 buttons total).
And help would be appreciated - this is my first cab.
- DigDreams
RickDIII
  • Last login:June 03, 2007, 10:18:28 pm
  • Finished 1st Cab!
Re: Best way to wire LED's?
« Reply #1 on: June 03, 2006, 11:36:46 pm »
Don't know if this is exactly what you are getting at, but I'm using two barrier strips (part # 274-670) with some jumper strips (part 274-650) from Radio Scrap.  They are a couple of bucks a piece and allow me to run the + to one of the sets of terminals (leaving 7 more screw downs) and the - to the second set of terminals (again 7 additional screw downs).  I'm pretty sure this is overkill, but I thought it might make troubleshooting easier.
Basically, the barrier strip I picked up is a block of 16 screw down terminals in rows of 2 (each connected) that are seperated by plastic barriers - forming 8 usable rows.  The jumper strip jumps accross each row, connecting them.  This allows you to share a connection with seperate screw downs.
Does the explanation make any sense?
Try this lousy diagram of a barrier strip.
____________________________
| X | X | X | X | X | X | X | X |
Or go to this site to see one:
http://www.oz.net/~coilgun/mark3/barrierstrips.htm
Good luck!
DigDreams
« Reply #2 on: June 04, 2006, 02:08:18 am »
That's almost what I need - just I need it "sideways".  In other words, the barrier strip connects sets of 2.  I want the shared connection going length ways.  Let me explain it this way...
|A|B|C|D|E|F|G|H
|1|2|3|4|5|6|7|8
A barrier strip would connect a to 1, b to 2, c to 3, and so on down the line.  What I want would connect all the letters together and all of the numbers together.  The goal is to have a long row of + and a long row of ground.   This way I can run individual +/- paired wires to my LEDs.
I know this thing exists, I just don't know what it's called.
- DigDreams
RickDIII
  • Finished 1st Cab!
« Reply #3 on: June 04, 2006, 09:44:02 am »
That's what I was getting at with the jumper strip.  If you put a jumper strip on a single barrier strip it would connect all of them giving you a strip of positive connections.  Add a second barrier strip/jumper combo and you have a strip for negative connections.
Good luck!
DigDreams
« Reply #4 on: June 04, 2006, 01:53:06 pm »
Got it!  Thanks!
- DigDreams
