Author Topic: Monitor mounting brackets, UK, Where?  (Read 1268 times)
lettuce
  • Make It So!
« on: June 01, 2006, 02:20:59 pm »
Where can i get a set of 4 Monitor mounting brackets here in the UK?
grantspain
Re: Monitor mounting brackets, UK, Where?
« Reply #1 on: June 02, 2006, 05:47:54 pm »
go to wickes buy some angle iron and make them yourself,its cheaper and faster
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #2 on: June 02, 2006, 08:21:10 pm »
I made some and show how on page six of my project thread.  Click the pic below if you're interested.
lettuce
  • Make It So!
« Reply #3 on: June 09, 2006, 11:28:30 am »
Can u go into more detail of how you managed to scure the monitor to the bracket, as its not very clear
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #4 on: June 09, 2006, 07:54:11 pm »
I bought a 1" square tube piece of steel, a 12x16 sheet of 18 gauge metal, and a 1/4"x2"x24" piece of aluminum.  I cut the 2" strip into smaller pieces.  I dog eared them so they wouldn't hit the t.v., yet still be in line with the holes.  I drilled holes the same size as the holes on the built in brackets on the monitor.  Once I had those 2" strips the way I wanted them, I clamped them to the 1" bar where they would need to be located to fit, and drilled and bolted them to the tubing.  Once I had all four pieces secured to the two sections of tube, I just bolted them to the monitor.  After that, I added the plate on the bottom by bending the angle of the sheet, clamping it in place, and again drilling and bolting.  I guess, in summary, take your time in measuring, making sure everything fits properly, then drill away.  It is more then sturdy enough for what it is doing.
