Author Topic: WG 25k7191/25K791+ArcadeVGA scrn bottom curls  (Read 2907 times)
jerryjanis
  • Last login:February 02, 2023, 01:56:44 am
  • Skate or Die!!!
    • Jake's Joystick
« on: March 05, 2003, 02:40:54 am »
I was having trouble running some resolutions on the ArcadeVGA with my WG 25k7191 monitor, and there's a brief thread on the Ultimarc site that I saw that fixed my problem.
The problem was that the bottom of the screen would curl for some resolutions - 800x600, 640x288, and most vertical games wouldn't display correctly.
http://ultimarc.com/messages/2665.html
It really made my day to find out how to fix it (it's just one of the pots inside the monitor that needs adjusting), so I thought I'd post it here in case anybody else is having the same problem.
MannyTC
  • Last login:May 12, 2003, 01:33:28 am
  • Jack Burton... Me!
Re:WG 25k7191/25K791+ArcadeVGA scrn bottom curls
« Reply #1 on: March 05, 2003, 08:56:04 pm »
Thats awesome. I have the same monitor and will probably be getting Andy's card too soon. I actually did see that thread and was wondering what POT he was referring to. I have been looking online for a manual for this monitor but have been unsuccesful in finding one. If you can share where you found the POT it would be appreciated.
Hey also got a ?, are you using Windows? If so what are your experiences so far with finding a good frontend for MAME to use with the ArcadeVGA/WG Monitor combo?
« Last Edit: March 05, 2003, 09:57:06 pm by MannyTC »
jerryjanis
  • Skate or Die!!!
    • Jake's Joystick
« Reply #2 on: March 05, 2003, 10:59:38 pm »
On my monitor, there is a sheet stuck to the back that labels the different pots and what they are.   The one that did the trick was labelled "50-60khz" I believe.  If you want me to take a picture of it, I will (I would have posted one but I have to pull the monitor out of the cabinet to take it).
It is a white pot that needs a screwdriver to turn it.
I haven't gotten as far as frontends yet.  I'm using Mame32 and .bat files for now.  I'll get to that one day.
