Author Topic: GP-Wiz49 wiring??  (Read 1082 times)
lettuce
  • Make It So!
GP-Wiz49 wiring??
« on: May 30, 2006, 01:04:17 pm »
I have a GP-Wiz49 interface No-Solder version, and am a bit unsure where to wire the left over wires from the IDE cable that dont plug into the 49-way joystick. Where do these extra strip of wires on the IDE cable go to?
RandyT
  • Last login:Today at 09:45:21 am
    • GroovyGameGear.com
Re: GP-Wiz49 wiring??
« Reply #1 on: May 30, 2006, 04:39:51 pm »
They go to buttons, etc.  But you may want to use a "euro" style terminal block in-between.  You can also wire them directly to your button wires.
Check out the diagram on the instruction sheet.  It will tell you which pin does what.
RandyT
lettuce
  • Make It So!
« Reply #2 on: May 30, 2006, 05:07:38 pm »
How many buttons can you wire to the GP-Wiz49?
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #3 on: May 30, 2006, 06:58:47 pm »
23 or more.
So you can wire a regular Happ Competition stick (or 2) plus all your buttons to the GPwiz in addition to the 49 way stick if you want.
I plan to use a GPwiz49 to power an entire control panel (minus the trackball and spinner of course)
lettuce
  • Make It So!
« Reply #4 on: May 31, 2006, 12:48:13 pm »
Ah, i think i have the GP-Wiz49 Eco version, that doesnt support than many buttons does it?
DaveMMR
« Reply #5 on: May 31, 2006, 02:10:15 pm »
No, I have the Eco too and it looks like I have about 23 Free Inputs (or 22 with a Joymode button).  You'll have more than enough to work with here.
