Author Topic: MaLa v1.0 RC4 available  (Read 5603 times)
swindus
  • Last login:July 28, 2021, 05:52:50 am
    • MaLa - M.A.M.E. Launcher
« on: May 30, 2006, 03:31:06 am »
Some small improvements and a lot of bugfixes:
Improvements
- Added an aspect ratio of 1.6 (16:10) to the layout. Create scalable layouts for wide screen displays.
- Added an definable aspect ratio to the layout. Create scalable layouts for any aspect ratio.
- Added 'Remove selection' function to MalaGamelist.
- MalaTree and MalaGamelist stay on top now when started via command line/from the options dialog.
- New emulator presets.
Bugfixes
- Access violation on opening the Info Window when no history.dat file is available.
- Desktop resolution not switching when using a scalable layout.
- Background music not starting on MaLa start.
- Game lists are not displayed/selectable on controller mapping tab sheet.
- Game lists are not displayed/selectable in auto game list switch checkboxes.
- Joystick in Exit window not working.
- MalaGamelist: Wrong emulator name of source list displayed when starting with command line parameter.
- Button 'Delete' on game list tab not working
http://mala.arcadezentrum.com/download.html
Quarterhorse
  • Last login:September 07, 2007, 01:25:17 pm
  • She tried grabbing Chuck's wheel -- ONCE
Re: MaLa v1.0 RC4 available
« Reply #1 on: May 30, 2006, 06:49:47 pm »
Looks like I'll be updating...I couldn't get the music to start on the last version.   Thanks for all your hardwork.  Next time Paypal gets some $$ in it I plan on donating.
loadman
  • Moderator
  • Last login:January 29, 2026, 07:18:10 pm
    • MaLa
« Reply #2 on: May 30, 2006, 07:12:19 pm »
FYI The background music feature did work in previous versions, it just didn't start automatically when MaLa started. You had to hit 'play' in options or 'Next song' on an allocated button.
