Author Topic: I'm not sure if this is a dumb question... (Encoder Content)  (Read 1026 times)
JonnyBoy
  • Last login:November 12, 2009, 01:59:00 pm
  • Inka Dinka Do
Well, I bought my Ipac used, and the one I bought came with a USB interface.
After hearing much talk of the general multiple keypress issues associated with USB, I decided to possibly order a new cable. But I was looking through my box of assorted computer stuff and found a USB to PS2 converter, and hooked it up. I can't tell if the multiple input issue is gone, I'm testing by myself. Does anybody have any experience with this?
I had to beat them to death with their own shoes...
JonnyBoy
  • Inka Dinka Do
Re: I'm not sure if this is a dumb question... (Encoder Content)
« Reply #1 on: May 25, 2006, 08:42:53 am »
Bueller?
ppilot
  • Last login:January 06, 2020, 01:33:27 pm
« Reply #2 on: May 25, 2006, 08:53:06 am »
You shouldn't have a problem with multiple keypresses when using an ipac through USB.
Tiger-Heli
    • Tiger-Heli
« Reply #3 on: May 26, 2006, 07:29:19 am »
See my page.  I-PAC has a limit of something like 14 or 16 simultaneous keypresses in USB mode.  Plenty for normal usage.
I have posted before about my tests with a PS/2 to USB converter and they worked, but not well.
I am not sure how the USB-PS/2 Converter would work.
OTOH, I think the USB cable is the special one, so if you wanted to go PS/2, you could likely just get a standard PS/2 M/M cable at the local supply store.  (Unless you have an I-PAC VE which is USB only.)
Everyone has their own opinions on USB vs. PS/2 and I will leave it at that for the rest of the world.
For me, I would make the decision based on what I wanted the device to do and what hardware I had available -
In other words -
TEST ONE - Functionality - i.e. if I had a removable (or desktop) panel that I planned to hot-swap in and out, I would go USB.  (Even though I currently do this with a PS/2 encoder and that works okay).  If the device were permanently installed, I would go PS/2 (given both options), b/c I feel it is a more straightforward and dedicated interface.  (In other words - you are emulating a keyboard.  The PS/2 keyboard port is pretty universally a keyboard interface.)
TEST TWO - Hardware - Comes down to what you want.  If you don't have legacy ports, I wouldn't worry about running the encoder in USB mode.  If you need to use a keyboard routinely with your application, and you have a PS/2 one already, it would make sense to run the encoder in USB mode.  If you want your USB ports available for other peripherals, it makes sense to use it with PS/2.
And in the end, while an interesting theoretical debate, I think the issue has been blown way out of proportion.
BTW, I currently have one of the least desirable (IMHO) setups - I run a desktop controller, under WinXP, with a PS/2 interface.  This means I have to run a PS/2 keyboard and hot-swap the interface (not supported by the PS/2 spec), b/c under XP if the PS/2 keyboard is not present at boot-up, the encoder will not be recognized if it is plugged in later.  That said, I don't have any real problems with it.
Real bottom line: If you feel like getting a PS/2 cable and testing, knock yourself out.  If you just stay with USB mode, you should be fine also!
