Author Topic: hdloader  (Read 3295 times)
whatzcrackn
  • Last login:January 19, 2019, 12:14:02 pm
  • U just won tickets to da 'GUN SHOW'
hdloader
« on: May 24, 2006, 07:03:09 am »
Can I install backups/imports using HDLoader w/o a mod chip?
Can I use a mod chip or dont need one?
pointdablame
Re: hdloader
« Reply #1 on: May 24, 2006, 12:55:32 pm »
With a real copy of HDLoader (or a memory card exploit and PSX game) you can do it without a modchip.  You will need to FTP the games to the hard drive through your PC, but a modchip is not needed.
You CAN use a modchip with HDLoader if you wanted to.  They can work together just fine.  It's not necessary however.
first off your and idiot
dennis808
  • Last login:May 13, 2021, 08:40:00 am
  • Holy Sanwa-sticks!
Re: hdloader
« Reply #2 on: May 24, 2006, 04:49:47 pm »
Yes, you can. I transfer the data by attaching the PS2-Harddrive to my PC via a USB adapter.
Transferring of games is much faster if you transfer that way using the program WinHIIP.
check out www.ps2hd.com for some tutorials.
"Complexity is the process by which the obvious is obscured by the irrelevant." -HSW
brained
  • Last login:February 11, 2026, 10:56:20 am
  • Raised by Atari
    • Nux
Re: hdloader
« Reply #3 on: May 26, 2006, 02:28:07 pm »
If you got HDLOADER u can install backup games directly, just by cogswaping the games.
Heres how to do it:
1) Load your HDLoader
2) Insert an Original PS2 Game with a big TOC (GTA Vice City, FFX, for example)
3) When the disc stops spinning, open your CD tray with the cog swap tool
4) Install your backup by choosing the install option from the menu.
5) Enjoy ;)
Stingray
Re: hdloader
« Reply #4 on: May 26, 2006, 04:45:33 pm »
You missed the part where you explain what a cogswap tool is. Please 'splain.
-S
pointdablame
Re: hdloader
« Reply #5 on: May 26, 2006, 04:58:20 pm »
-S
You have to have the CD tray cover of your PS2 off and you need to use a tool to push a small white cog open manually to open the tray of the disc drive.
It's been known to cause problems with the drive, and frankly, its a pain in the ass.  It works, but I'd much rather just FTP to the drive.  And beyond that, a mod chip is really the easiest way to go IMO.
crashwg
Re: hdloader
« Reply #6 on: May 27, 2006, 04:56:05 pm »
I'd go with this method.  In less than 2 minutes you can have your PS2's HD hooked up to your PC and from there it's as simple as opening a program and clicking a button.
Of course you don't need a usb/firewire enclosure/adapter but if you don't have one, like I don't, you'll have to put the HD in your computer which requires a restart.  But in my opinion it's still easier than cogswapping and much faster than FTPing.
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
SOAPboy
  • Last login:August 01, 2009, 03:36:12 am
  • ..::GeeK::..
Re: hdloader
« Reply #7 on: May 27, 2006, 06:15:03 pm »
-S
http://www.ps2cover.com/ps2-cover-blue-v9v10.shtml
Makes life easier.. Bought one a year or two ago, and frankly its the best money ive spent on console modding..
pointdablame
Re: hdloader
« Reply #8 on: May 27, 2006, 08:43:22 pm »
-S
Yeah I had a flip-top on my older PS2 before I got a modded one.  They work well.
