Author Topic: Video Cable Length Limitations  (Read 1017 times)
JeepMonkey
  • Last login:July 13, 2012, 01:51:24 pm
« on: May 23, 2006, 06:16:04 pm »
Can anyone tell me how long a video cable can be without having to get something like a repeater?  Any difference between analog and digital cable limitations?
Pins:  Theatre Of Magic, JP The Lost World, Revenge From Mars
Generic Eric
Re: Video Cable Length Limitations
« Reply #1 on: May 23, 2006, 09:10:52 pm »
What is the video cable for?  Your PC? Your TV? Your arcade monitor?
What is the desired cable length you want to run?
JeepMonkey
« Reply #2 on: May 23, 2006, 10:36:13 pm »
It is for an industrial process control and monitoring system.  We will have two PCs running two flat panel monitors each.  The towers will be appoximately 50' from the monitors.  So I was wondering what the difference between analog and digital signal cables would be when talking a 50' run.
Generic Eric
« Reply #3 on: May 23, 2006, 11:11:47 pm »
I'll check what we are doing at work.  I think our runs were like 20 foot or so.  I will check on what kind of KVM switch we have at work.  I think it ran over ethernet.
I read you can do rca or svideo over ethernet with some sort of video to ethernet balun (spelling) they were like $150 a piece and you needed one for each end.  I think they are made or sold at smart home.
arcadegamenut
  • Last login:July 16, 2010, 01:48:45 pm
« Reply #4 on: May 23, 2006, 11:14:41 pm »
I don't know the specific answer to your question, but I'd think you'd be okay.
I know I've used 25 ft component cables in my home video setup and didn't have any issues. I bought them from a site called monoprice (http://www.monoprice.com). Good prices and I got the stuff pretty quick.
Anyway, a quick glance at their site shows they sell 100ft SVGA monitor cables, 50 ft composite cables and 100ft component cables.
So again, I doubt you'd have any problems.
JeepMonkey
« Reply #5 on: May 23, 2006, 11:46:23 pm »
Thanks for the input.  Any idea of the limitations between analog and digital?
