Author Topic: optiwiz cable to optiwiz orientation?  (Read 1117 times)
kiddk1
  • Last login:August 01, 2022, 10:58:08 am
  • HAP KI DO
« on: May 18, 2006, 05:26:57 pm »
do I have this cable attached the right way, it attaches either way so I dont know which is correct?  thanks
Its easy to like someone,
If you dont know them very well.
JLR2000
  • Last login:February 18, 2021, 02:49:16 pm
  • There is NO Sanctuary...
    • WWW
Re: optiwiz cable to optiwiz orientation?
« Reply #1 on: May 18, 2006, 08:59:24 pm »
Yes, that is how mine is connected.  The true test is if the movement is correct when you connect it it the trackball - if not, reverse it.  But as I said, that's how mine is connected.
kiddk1
  • HAP KI DO
« Reply #2 on: May 18, 2006, 09:18:08 pm »
thanks I will try it, my main concern was making sure not to fry anything by connecting it the wrong way.
do you have the buttons connected if so can you post a pic or a "how to" so I can connect mine. thanks
« Last Edit: May 18, 2006, 09:32:20 pm by kiddk1 »
JLR2000
    • WWW
« Reply #3 on: May 18, 2006, 09:52:31 pm »
See the photo for where to connect the button wires.  I found that those internal sound cables (from the CD drive to the soundcard) fit these pins nicely.  You  might need to hack a couple to get all the wires you need but you'll find out that it's pretty simple.
The Optiwiz is marked for what goes where, but I elaborated in the photo.
Good luck.
kiddk1
  • HAP KI DO
« Reply #4 on: May 19, 2006, 02:05:00 pm »
SWEET thanks
