Author Topic: using the escape button to quit and arcade frontends  (Read 5422 times)
jamesish
  • Last login:December 11, 2012, 07:00:49 pm
« on: May 17, 2006, 10:07:16 pm »
i have the jukebox program set to close when i press escape.
my problem comes in when i open up the queue list, there doesnt seem to be a way to close the box without pressing escape, which also closes the entire application.  Is there a way around this?
SalmonKing
  • Moderator
  • Last login:August 16, 2007, 10:45:44 am
  • SK Jukebox
Re: using the escape button to quit and arcade frontends
« Reply #1 on: May 18, 2006, 01:52:27 am »
What have you got the 'Back' button mapped to?  If the key is doubled up (i.e. both mapped to Esc), you'll need remap it to something else.
jamesish
« Reply #2 on: May 18, 2006, 09:38:34 pm »
my back button is mapped to the numpad's del key, and it doesnt go back, just gives a windows chime ><
SalmonKing
  • Moderator
  • SK Jukebox
« Reply #3 on: May 18, 2006, 11:39:25 pm »
Backspace should clear that number too, but I have mapped to those same keys and it works fine.  I would like to bring up that it will only be registered as 'Delete' when Num Lock is off, otherwise it is registered as a full stop/decimal.
