Author Topic: How to Construct a Box to hang my Touch Screen on 1/2 Drywall???  (Read 1061 times)
Negativecreep0
  • Last login:November 28, 2020, 10:59:49 am
ok guys here is what I have so far I have the touch screen front and side shots, and a front frame that goes over the touch screen (made of 1/2" mdf). My dillema is how would I go about constructing a box to house this touch screen in? I was thinking maybe a hinge on the side of the face plate that the monitor is attached to so i could swing the box open in case I need to Access anything? But then I am worried about the weight pulling the face plate off of the box (ALSO HINGES are ugly I want to maybe do this this maybe with a hidden hinge or something (ideas))?Any ideas on how to construct the rest of the box or how to mount the monitor in the box on the wall?  Thanks!!!!
RickDIII
  • Last login:June 03, 2007, 10:18:28 pm
  • Finished 1st Cab!
Re: How to Construct a Box to hang my Touch Screen on 1/2 Drywall???
« Reply #1 on: May 18, 2006, 10:32:47 am »
Not sure if I understand fully what you want to do.  But I think you are saying that you will build a box, put the touchscreen in it and then mount the whole assembly on the wall?
I think there are a couple of ways you could handle this.
1.  Reverse your thinking - instead of having the front of the box open up, I might make it so the back could be removed.  Maybe a set of slots dado'd or routed into the mdf so that you could mount the back panel to the wall and then slide the rest of the box onto it.
2.  You could follow your first idea.  I think you are looking for what are commonly called french hinges.  These are the hidden type that are used for the inside of cabinet doors.  Put those on one side and then a set of catches on the other and the frame should stay secure.
Digression - just thinking, but is the touchscreen thin enough to mount it inside the wall - so the face is flush with the surface?  Not a big job, but a very cool effect!
Just some ideas, hope they help.
divemaster127
  • Trade Count: (+60)
  • Last login:December 02, 2018, 08:05:08 pm
  • My webstore is arcadeemulator.net
    • arcadeemulator.net
« Reply #2 on: May 18, 2006, 10:50:47 am »
you can get a micro flat screen mount by peerless & work your box around this, i provide these to the military for the coast guard & navy they look great & are very popular where space is a premium
dm
I carry both ultimarc & happ items, all brand new & I ship from the united states. My online store is ARCADEEMULATOR.NET, pm if I can help in anyway.
