Author Topic: Hiding XP - Password stuck  (Read 1895 times)
MPTech
  • Last login:January 05, 2025, 03:58:54 pm
  • UltimateArcade completed!
« on: May 14, 2006, 11:43:09 pm »
I didn't want to hi-jack the "Hiding XP" topic, but I would really appreciate some help.
After I installed the animated MAME boot screen, the password logon came up and I proceeded to step 2:
2. Getting rid of the Welcome screen
i) Start Menu -> Control Panel + select User Accounts.
ii) Select "Change the way users log on or off"
iii) Un-tick the "Use the Welcome screen" + apply options.  Close the User Accounts window.
iv) Start Menu -> Run  and enter control userpasswords2
v) Un-tick the "User must enter a username and password to use this computer"
vi) Enter the password for the person you want to login as.
I wanted it to continue logging in as the Administrator with no password (as it did before), so when it asked the password I hit Enter and did not input one.
But when I rebooted, it would not let me in and I received this message: "Unable to log you on because of an account restriction".
Now I can't logon in Administrator.  I can login as a username I established, but it will not allow me to make any changes or run MSCONFIG (no admin privileges).
How do I log back in as Administrator?  (with no password?)
MPTech
   Better living thru technology!   ;-)
loadman
  • Last login:January 29, 2026, 07:18:10 pm
    • MaLa
Re: Hiding XP - Password stuck
« Reply #1 on: May 15, 2006, 05:43:45 am »
Hi,
Someone may have another idea but worst case scenario you can reset the password with tools found here:
http://www.petri.co.il/forgot_administrator_password.htm#1
Good Luck. I have used these tools on a few PC's with great success.
...If you are going to set a 'autologin' via control userpasswords2.   I would recommend setting up another account for that (with admin privileges if you must / you can change that back later) .
KenToad
  • Last login:Yesterday at 08:40:13 pm
  • Flap Flap Flap
« Reply #2 on: May 15, 2006, 08:01:18 am »
I had a similar problem: Following the above link should work.  Also, you can try logging in using safemode if you still have troubles even after you have zapped the password for sure.  I had to use safemode.  Good luck.
KenToad
MPTech
« Reply #3 on: May 24, 2006, 09:10:23 pm »
I tried logging into safe mode and it allowed me to change/re-set the password, but the password didn't take or something, because it would not allow me to log back in normally with the new password.
I also tried the utility / bootdisk option.  I upladed the file (3 times, using different emails) and have not received a reply yet.
Any other suggestions?????
thanks
MPTech
zvar
  • Last login:October 08, 2019, 11:39:56 pm
  • One of these days I'll think of somthing cute.
« Reply #4 on: May 25, 2006, 02:20:21 am »
Offline NT Password & Registry Editor
I've used this program several times to reset clients passwords for both XP and 2k.
You just dl and create a boot disk (CD of floppy) and boot from it.
Steven
